- #50 [alexanderkoo], 21-12-18 08:41High carb is bad to health but not directly related to sciatica. Read it somewhere, copper deficiency can cause weakness in inter-vertebra discs and also graying hair. Heavy lifting without proper posture, too much bending of waist, is the spark though the fuel was there long time ago.
- #49 [cornercube], 21-12-18 07:20#46... 突然腳軟...針灸,拔罐,或推拿有冇用?
已經身弱就唔針灸, 而且只針無灸(=只瀉無補)
google:
暈針 針灸
tinyurl.com/2p92p8h8
只針無灸 只瀉無補
tinyurl.com/mt566v7u
拔罐禁忌
tinyurl.com/3uere2yu
按摩, 廿年前 幫趁過.
https://www.review33.com/chat/index.php?topic=17201110091432&post=4#message_reply
最後修改時間: 2021-12-18 07:23:04 - #48 [simon62], 21-12-17 22:10乜水講食麵包會出事咁得意既?
每日食幾多,食乜類型麵包,食左幾多年,麵包當飯食前有無做過 body check ,期間有無受過外傷等等,乜資料都無,由食麵包引起坐骨神經病既病理係乜,仲講唔講科學架? -
- #47 [ivchan123], 21-12-17 21:37小弟左邊梨狀肌症候群引致神經痛,之前都有突然之間左膝頭冇力腳軟,左小腿麻痹等問題,而家做物理治療同針灸,左膝冇力問題冇左,小腿麻痹有改善,但左大腿明顯幼起碼半吋
- #46 [audiofan], 21-12-17 21:30#1, 18
急症室 (打止痛針加止痛藥丸, 冇效),普通科(加強止痛丸有嗎啡成份,無效),針灸,都無效。結果10月中去睇中大骨科脊椎專科,照MRI, 醫生話唔使做手術,開咗兩隻藥Pregabalin(75mg) Etoricoxib(90mg), 當晚有覺好瞓,比以前好大概70%,兩個星期後複診, 第一隻藥加到100mg,止痛去到95%,而家基本上冇神經痛, 繼續食嗰兩隻藥加埋維他命B6/B12,但問題呢就係雙腳weak,感覺酸軟,冇乜力(左腳比較差),試過行行吓,毫無先兆之下跪低, 着褲穿完左腳到右腳, 突然腳軟,成個人向後番, 擦損手踭。今日行街 ,平路,已經行得好慢,步步為營,突然毫無先兆,向前仆,刮損膝頭!
有冇師兄有同樣經驗?中醫針灸,拔罐,或推拿有冇用? 謝謝。 - #45 [cornercube], 21-10-18 07:41google:
风湿骨刺膏有無效?
tinyurl.com/ynpkupaa
抗骨質增生丸有無效?骨刺
tinyurl.com/ynpkupaa - #44 [哇哈哈], 21-10-14 11:36#42 ich hing,
啊,thank you.
我估下、會唔會係prednisolone + prednisone?
揀佢係因為資料夠多又經過咗三十幾年光景。唔駛盲鍾鍾去睇。
加上現在開展嘅分子醫學,又幫助到可以再深入D了解當中嘅機制。 - #43 [alexanderkoo], 21-10-14 08:07Back to the topic, my colleagues are still fine after 15-20 years, without surgery, recovered at least 80% by their own. But ailment would come back again if not careful. If it's at advanced stage, surgery would be the ultimate solution. No drug can eliminate the spine spur or repair the slipped(damaged) disc.
- #42 [ich], 21-10-14 07:45#37
哇兄,
Meta analysis我冇做過,好tedious,亦要有好強 critical appraisal skills and knowledge. 另外點解揀prednisolone? 香港以前好怪,同一settings會有prednisolone + prednisolone. Search 時 keywords 要 "OR" 包哂兩隻.你想check in general glucocorticoids, exclude mineralocorticoids;定或steroid class in general?
自己興趣就 abstract勉強可以.真正research當然全份paper由頭睇到尾.
最後修改時間: 2021-10-14 07:47:07 - #41 [cornercube], 21-10-14 07:19google:
bone spur and inflammation
tinyurl.com/e45vp2c2
food that causes joint inflammation
tinyurl.com/cr6b3f9
Foods to Avoid if You Have Chronic Joint Pain
tinyurl.com/bc4abs88
https://www.nasabone.com/blog/foods-to-avoid-if-you-have-chronic-joint-pain
最後修改時間: 2021-10-14 07:22:59 - #40 [哇哈哈], 21-10-13 22:100925 hing
我意思係: (>其他的都係不學無術的垃圾 ) 見得多, 唔識答啦。已經冇乜..反應。
但题外話,有感而發。
#39這句話其實是很存在主義的。就是一個人的感受感知,只有當時人知道,也因為如此,也只有當時人才可以為自己作出選擇。
N年前睇過卡繆.突然跳番出黎.
最後修改時間: 2021-10-13 22:12:39 - #39 [0925], 21-10-13 21:08哇哈哈兄,
點樣處理自己的問題其實其他人冇資格參與及干涉,自得其樂就 OK! - #38 [哇哈哈], 21-10-13 21:040925 hing
唔識答啦。
見過嘅有,聽聞過嘅有。已經冇乜分應。
我自己盡用自然療法。 - #37 [哇哈哈], 21-10-13 20:50#34 ich hing,
我我都想整份系統性回顧。主題大約是 prednisolone 繼發性 secondary to yyy 之間的暗示性關聯。可否比d意見有咩地方唔好忽略咗。 - #36 [0925], 21-10-13 20:49哇哈哈兄,
我有需要至食兩,叁天/次,應該影響不大,我這區除了已離世的翁烱培醫生之外,其他的都係不學無術的垃圾(包括同年輕護士經常偷情的菜堅)。 - #35 [哇哈哈], 21-10-13 20:370925 hing,
Etoricoxib屬於高選擇性的COX-2抑制劑, 此類藥物被發現長期服用可能對心血管有不良影響,所以只適用於對胃腸潰瘍及併發症有高危的病人並必須由醫生評估病人的心血管風險才可使用。
小心用啊。
https://www.drugoffice.gov.hk/eps/do/tc/consumer/news_informations/dm_03.html
有冇考慮過 tramadol ?
試過兩次整亲了腰,事後幾日只要有小小重量或壓力落到腰間,絕對痺痛到渗入心肺,冇可能行到。my case.
最後修改時間: 2021-10-13 20:41:58 - #34 [ich], 21-10-13 17:40PubMed results:
sciatica AND gluten
Risks factors of LBP and sciatica
最後修改時間: 2021-10-13 17:46:21 - #33 [cornercube], 21-10-13 15:08google
sciatica and gluten related ?
tinyurl.com/5e38jce3 - #32 [encore], 21-10-13 14:59椎間盤發炎而腫脹突出壓住神經線,引致屁股,大腿及小腿抽痛,通常要六個星期才消炎,
所以要加強腰橫肌力訓練.咁就會保護得好D,我自己就由190磅減到140磅之後,就有好大改善.
至於血糖太高亦都會引致關節及血管發炎,麵包係高升糖食物,太多當然係會有影響. - #31 [0925], 21-10-13 14:41多年前在大碌國工作時突然右后面盤骨深處劇痛,坐、瞓和起床都好痛,睇醫生開 celecoxib 食唔止痛,轉 etoricoxib 食兩次就唔再痛,老婆膝關節勞損排緊期換骹,睇醫生開咗幾拾排 celecoxib 俾佢。
最後修改時間: 2021-10-13 14:42:08 - 下一頁 (1 of 3)
