- #16 [Neontetra], 18-12-10 21:54
- #15 [Neontetra], 18-12-10 20:53
會吾會 係改善工程,分分鐘又執幾皮嘢 x 2 - #14 [DcAss], 18-12-10 20:50Growing marajuana/cannabis, if cultivated indoors, requires C02 source (piping) and UV-lights and the aluminum foil forms a canopy acting like reflectors to intenisfy the heat/light to promote more rapid growth. Usually basements, closets, sheds, or unused/hidden rooms are where such plant harvesting is setup.
外國有人話係有料到咁意思,同一樓鳳着粉红色光管咁解。 -
- #13 [ef9], 18-12-10 18:59會吾會 係改善工程,分分鐘又執幾皮嘢
- #12 [奸人堅], 18-12-10 18:44鴨記男厠2/F(premium economy class果層)
可能痴漢貼女廁去錯貼男廁 - #11 [jwong852], 18-12-10 18:41先試吓自問自答:
會唔會係防止上面跌D老鼠屎, 雀屎落來, 方便清潔呢 ? - #10 [Kk6666], 18-12-10 18:24駁音響地盒
- #9 [jwong852], 18-12-10 18:22#4條LINK的原因, 都與鴨記公廁的情況無關.
另外條水線係接住個窗框, 與錫紙無關, 只是位置接近.
如果話下面的玻璃本來都有錫紙, 但俾人搣走, 又無理由咁齊整, 所有窗都淨最上果塊.
暫時都係無一個合理解釋, 要等高人解答.
PS: 行開果頭, 可以上去研究吓. - #8 [呀金], 18-12-10 17:26嗰條好似是"地線" x2
所以應該唔關事。 - #7 [lym], 18-12-10 17:26焗香腸
- #6 [tonywong], 18-12-10 17:24嗰條好似是"地線"
- #5 [DcAss], 18-12-10 17:17好似同格離條電線lung住個電盒有關係。
Solar energy?
最後修改時間: 2018-12-10 17:21:56 - #4 [cornercube], 18-12-10 16:46斷估
原先 塊塊都貼咗,
搣落嚟..#2,#3..
搣搣下... 唔夠高...
https://www.hunker.com/13413654/why-do-people-put-tin-foil-on-their-windows
最後修改時間: 2018-12-10 16:59:47 - #3 [Mike*Pang], 18-12-10 16:30追龍以後唔使帶錫紙。
- #2 [DcAss], 18-12-10 16:17搣落嚟老童就有得用。
- #1 [jwong852], 18-12-10 15:53鴨記男厠2/F(premium economy class果層),所有窗口最上塊玻璃都貼了錫紙,有無人知有乜用?
咦,會唔會係于擾通訊電波?驚有人裝無線攝錄鏡頭?
