- #41 [alexanderkoo], 17-07-25 07:27
- #42 [0925], 17-07-25 07:40
最後修改時間: 2017-07-25 07:40:59 - #43 [bearbearloo], 17-07-25 09:36用大力 電批 Dup d "林"料 eg. 鋁OK;
d料 硬少少 或 窿深, M3咁幼 就易斷Dup.
>>> Thanks cornercube
1) 我用類似B的充電鑽,做頗多DIY,夠用,但有人會建議用18V或以上充電鑽。
2) 未試過扭斷螺絲,但B可以轉8, 11, 14等調節扭力。
3),4),5) 舊年要裝拆木屋圍欄,扭過百粒以上螺絲,扭力35Nm可應付95%以上情況,唔夠力係螺絲有8CM以上長,螺絲頭入木成1CM。
>>> Thanks 2628939
最後修改時間: 2017-07-25 09:36:53 -
- #44 [bearbearloo], 17-07-25 09:38cornercube
332D 係 CHUCK頭,
直夾批嘴 或 加adaptor 做批, 個人 覺得 麻麻.
請問有無咩其它 型號/品牌 介紹? - #45 [cornercube], 17-07-25 09:56買番佢d 用hex shank socket頭嘅電批;
但又到加CHUCK頭做鑽 唔好用.
最後修改時間: 2017-07-25 09:58:11 - #46 [bearbearloo], 17-07-26 11:15Thanks cornercube c hing
- #47 [cornercube], 17-07-26 15:46
- #48 [neontetra], 17-07-27 06:47
Hilti DD350 - #49 [0925], 19-07-09 23:17淘寶不連電池人仔$1200,2.6 joules,送一支德國造同牌子石屎鑽咀。
最後修改時間: 2019-07-09 23:18:06 - #50 [alexanderkoo], 19-07-10 07:14Most drills are MIC or SE Asia.(MIJ is rare, don't imagine) Dewalt is only good for models made in USA. Metabo 2660-2 is still made in Germany.(amazon.de) HK 2000 plus $600 for shipment. For such shipping cost(adding a bit more), I am going to buy Worx hammer drill WU326D from Taobao instead.(used once each month)
最後修改時間: 2019-07-10 07:16:04 - #51 [0925], 19-07-10 08:12
- #52 [0925], 19-07-18 01:23
最後修改時間: 2019-07-18 01:23:11 - #53 [0925], 19-07-18 10:38#52 + 1
最後修改時間: 2019-07-18 10:40:10 - #54 [0925], 19-07-19 14:48
有兩支 Hilti。
最後修改時間: 2019-07-19 14:50:01 - #55 [0925], 19-07-21 00:15
TEST Makita HR2810 800W/2.9J Vs Metabo UHE 2850 Multi 1010W/2.8J
最後修改時間: 2019-07-21 00:16:51 - #56 [0925], 19-07-22 22:12淘寶幾拾蚊人仔一個連海綿PP料工具箱。
最後修改時間: 2019-07-22 22:12:56 - 返回 ...
Hitachi DH-24PH 730w
Makita HR2452 780w
Only suitable for mounting the hammer drill bit but not for depth of 150mm due to friction and heavy loading. Two different things. $1000 for such purpose, impossible. For infrequent user, can drill 13mm first and increase the dia. of drill bit. Quite common.
