- #7 [alexanderkoo], 18-06-19 19:01
- #6 [samflower], 18-06-19 16:50#5 x2
除非係私人珍藏,唔想俾人睇,否則果十幾盒俾人轉啦,乾手淨腳 - #5 [majesty], 18-06-19 16:36深之都商場3樓電梯直入
左手面有間店專幫人數碼化
呢D錢比人賺啦 -
- #4 [cambridge], 18-06-19 16:31It is pal
Checked eBay and it seems that most of them have not stated explicitly if they are pal or ntsc.
Since most of them are from US, I think they are NTSC - #3 [IHKOHK], 18-06-19 10:58Do you know your tape is NTSC or Pal?
Find HI 8 Player.
最後修改時間: 2018-06-19 11:07:19 - #2 [alexanderkoo], 18-06-19 09:08PAL or NTSC? Two different camcorders.(or PAL device with NTSC playback conversion so suitable for both PAL or NTSC tape) Even if you can buy a used one, it's likely to be faulty. You need digital signal for input to PC via IEEE 1394.(analogue to digital PC card is expensive) It's rare find even entrusted to a shop.
- #1 [cambridge], 18-06-19 08:58各位師兄,最近想將家中十多盒舊v8&H8帶轉做mp4 format,但原本的camcoder壞了,請問要注意甚麼?
例如要否留意N or Pal 綫?
如何capture 入電腦,有何推薦?
那裡買舊的dv 攝影機好?
* 不打算做editing ,只是轉做digital format
Thx a lot
最後修改時間: 2018-06-19 08:59:24 - 返回 ...
Of course. The camcorder should end with an E for PAL system. You need a camcorder plus a DVD tabletop hard disc recorder. Both are antiques.
