- #17 [bankguy], 23-05-30 17:38[#15] 通常佢拆舊機嗰陣,就有個?仔拆新機包裝,效率非常高。
- #16 [alexanderkoo], 23-05-29 07:57He was an ex-Olympic weightlifter. Even so, could hurt the back if not careful. That's why small chain hoist in my house.
- #15 [徐福], 23-05-28 18:52上年我換匹半冷氣機,只有一個師傅來,最後 要姐姐幫手托上窗台,大約4-5尺高。
- #14 [alexanderkoo], 23-05-28 09:132 hp RC is bound to be noisy.
最後修改時間: 2023-05-28 09:14:13 - #13 [alexanderkoo], 23-05-28 06:36No special tool for lifting, simply use manpower, very primitive(no harness, no eye bolt) Must lift from ground for better strength, not from ladder. For DIY work, I lift from ground using eyebolt and manual chain hoist.(got two) up to 1.5hp. I took it out for cleaning or painting and put it back. But watch out for your back.
For outdoor unit of split type, must use eyebolt and canvas sling(min. 1 ton) for safety reason. Plenty of them on Taobao yet inexpensive. But 99% C-fu would skim the work. Any mishaps, you're in great trouble. - #12 [敗家仔], 23-05-27 23:13起碼兩個,裝分體三個四個
一個師傅帶幾個o靚仔
快d搞掂就快d做下一單
一條友夾硬黎一陣整親咪盞睇醫生兼開吾到工
佢地做開知道曬呢d道理 - #11 [沉默的膏蟹], 23-05-27 23:12基本安裝 , 底架加吊臂, 拆埋舊機$600左右
- #10 [lym], 23-05-27 23:00一日吾會得一單,加下水兜,換下曲架,應該都夠食既。
- #9 [Jasper], 23-05-27 22:54收我$580裝機費, 我以為得一個
- #8 [mcdull], 23-05-27 22:51一般兩個, 如果一個上來, 你都唔好比佢裝啦.
- #7 [0925], 23-05-27 22:191個師傅係咪無可能收走部2匹機?<
窗口機差不多 60 kg 哦!
就算個師傅話佢可以一個人裝拆你都唔好信啦!
1匹半淨冷都差不多 35kg。
最後修改時間: 2023-05-27 22:25:38 - #6 [rickkklam], 23-05-27 22:10我上次兩個 一個係大肥佬
- #5 [lekin], 23-05-27 22:06:安裝兩匹半,兩個
- #4 [沉默的膏蟹], 23-05-27 22:023/4匹都應該2個, 有人托住遞部機過去好裝好多.
- #3 [Jasper], 23-05-27 22:02其實應該咁問, 黎緊諗住2匹換1匹半
1個師傅係咪無可能收走部2匹機? - #2 [lym], 23-05-27 21:44我見有兩個整。上次三個,一個教路,另外那兩個應改未學滿。
- #1 [Jasper], 23-05-27 21:36部機咁重, 係咪要兩條友先「豆」到上窗台位?
定一條友, 用D特殊裝備, 就可以「豆」到上去?
thx! - 返回 ...
