- #7 [cj8437], 22-10-01 10:46靈芝是打不到粉的, 我飲咗靈芝茶6年, 我膽固醇 血壓等數據全部正常(我快登六了),如有興趣可pm我怎樣煲靈芝茶。
- #6 [故人], 22-10-01 08:52人人身體不同,這類食品未必適合。
- #5 [alexanderkoo], 22-10-01 08:40Better with extract and broken down into smaller molecules for easy absorption such Kinoko brand AHCC. Always keep 1 bottle 750mg capsules in hand.(discontinued many times, only 500mg available) Don't buy the "sales talk" ones.
If I remember correctly, the shop is "Kong Cheong" Mrs Fung. Wife used to buy from this shop, more reliable. In fact, the area is the wholesale for the territory.
最後修改時間: 2022-10-01 08:44:07 -
- #4 [blackboyslim], 22-10-01 07:42街坊小店, 可以問下佢, 喺佢度買少少嘢, 例如花旗參, 跟住問佢可唔可以搭單幫你磨
- #3 [alexanderkoo], 22-10-01 05:45Some large herbal shops got crusher if purchased from her. Opposite to Sai Ying pun clinic. Beware if buying powder direct due to quality issue.
Taobao got similar benchtop appliance.
最後修改時間: 2022-10-01 05:46:26 - #2 [沉默的膏蟹], 22-10-01 00:04一係買現成提煉好既靈芝丸/膠囊,一係食多d冬菇。
- #1 [richmond168], 22-09-30 22:42老人家身體唔好、睇吓如果可以磨成粉,又可唔可以就咁食或者沖水飲?感謝感謝!
