- #11 [Kelvinzy], 23-02-02 09:02
- #10 [new68u], 23-02-02 08:48要服務快唔想煩,TGC SIMPA。
- #9 [alexanderkoo], 23-02-02 07:14Can consider changing to induction stove, better than expected wrt heating kW, don't judge by number. Town gas, much heat loss due to open construction of stove. Clean, no fume gas emission(a % of carbon monoxide), less intense heat in summer, safe, can use count down timer for stewing. Simply run a cable from the main board and using 40A pilot light switch or terminal block. Should be of short distance. Not recommended only when using electric water heater as well due to higher loading.
- #8 [MinnaNoTabo], 23-02-02 00:10
- #7 [MinnaNoTabo], 23-02-02 00:02https://www.fortress.com.hk/zt/product/rg32s-tg-table-top-gas-cooker-2-burners-/p/BP_11913497
有5.9 千瓦,炒餸夠晒鑊氣
最後修改時間: 2023-02-02 00:05:56 - #6 [patrick88], 23-02-02 00:00重用緊 Panasonic 煤氣煮食爐, MIJ
最後修改時間: 2023-02-02 00:00:22 - #5 [olddude], 23-02-01 23:58兩頭以前會買Panasonic依家無出改用Rasonic
- #4 [patrick88], 23-02-01 23:16蜘蛛絲, MIJ
- #3 [PT100], 23-02-01 23:09兩個牌子都用過,SIMPA得個平字,啲用料好單薄吓,冇咁耐用!
SIMPA兩個爐頭火力係一樣,而林內左面火力係大啲方便炒嘢!
最後修改時間: 2023-02-01 23:12:59 - #2 [0925], 23-02-01 18:19https://www.asiagas.com.hk/tgcp/1039-SRDB62-S.html
Simpa 得唔得?
林內3頭壞咗冇得修理和更新
改細窿裝 Simpa
最後修改時間: 2023-02-01 18:29:52 - #1 [dumbdumb], 23-02-01 18:04現在用緊林內座枱式兩爐頭
MIJ 德國面板
