- #31 [patrick88], 23-02-03 21:14
- #30 [呀金], 23-02-03 13:31#26
Yes,煤氣人員檢查/維修時,見到會通知住戶趕快處理。 - #29 [alexanderkoo], 23-02-03 11:24Must have kitchen door open and leave the living room window ajar for complete air circulation. If opening kitchen window only, kind of air short circuit.(foul air as well.
Some chefs in China place porcelain rings underneath the pot for better heat trapping. Not for ordinary stove
最後修改時間: 2023-02-03 11:26:39 -
- #28 [Kelvinzy], 23-02-03 11:10我裝咗個煤氣報警器
安心好多
依啲嘢喺歐美家庭喺標準配置 - #27 [alexanderkoo], 23-02-03 10:50Can't act against the Ordinance especially for gas and electricity, which can be lethal and causing explosion. Even for handling lithium ion battery, highly flammable.
But don't worry, folks here only talk without action. Or already having other solutions in mind.
最後修改時間: 2023-02-03 10:51:37 - #26 [phil.ng], 23-02-03 10:49條喉有寫日期!
- #25 [degalle], 23-02-03 10:36呢度乜嘢都有人想試DIY, 有d 嘢有時間空間唔影響自己及家人身家、性命無妨玩下DIY, 可以增進生活樂趣又慳返幾餐買餸。
有d 嘢立亂DIY 不特累及自己,家人,隨時累街坊,例如玩氣體爐換喉換管道,點解有d 行業需花時間學師學藝成為技工技師?唔熟行自己落手DIY 隨時引起災難,自己或/及家人傷亡,甚至累街坊,賠償都賠唔起!腥港好在地少地貴,否則又有人會玩起樓DIY, 嗰時到處死人塌樓。 - #24 [alexanderkoo], 23-02-03 10:11I am still TCG cooker(with central stove) , bought as used at $1500 about 15 years ago. I can't see any substantial difference wrt brand as long as the flame is blue(not yellowish due to incomplete combustion) Of course, new one must perform better similar to AC. Induction cooker is a lot energy efficient, saving can be at least 30% based on rough estimate though electricity cost has escalated.
最後修改時間: 2023-02-03 10:12:46 - #23 [呀金], 23-02-02 21:48喉有期限,煤氣公司如果認為有安全問題,可以唔供氣。
- #22 [沉默的膏蟹], 23-02-02 21:32自己安裝?你有牌咪得。否則可能害到人而且冇保養。
代理裝收$350~600(煤氣),一般包1米喉。
最後修改時間: 2023-02-02 21:36:41 - #21 [dumbdumb], 23-02-02 21:26我見到好多都話唔包安裝,自己可以安裝嗎?我現在條喉已經好舊
- #20 [CS168], 23-02-02 21:10能源效益係最重要,
其次6.5k 大火力!
用過兩部煤氣公司產品 TGC !!
煤氣費用貴到禾唔敢再用落去,
煤氣公司解釋,用舊咗,係其中一個原因。
禾最終,將TGC煤氣熱水爐及煮食爐棄掉,改用台制櫻花牌!
直接每曰叫工人用6公升電熱水煲煲滾水
最後修改時間: 2023-02-02 21:15:41 - #19 [ran], 23-02-02 20:05強力建議要換有時間掣的。
- #18 [Kelvinzy], 23-02-02 16:59煤氣熱水爐我用Simpa,前手業主留低
我又用了12年
想講好話但又怕部機小氣...... - #17 [0925], 23-02-02 16:55唔係同 Simpa 講好話,#2 呢隻已用了兩年零八個月,仍運作正常。
建議用開座檯兩頭的,改為用一個單頭加一個電磁爐,炒餸 + 煲湯/水 冇以前咁熱。
最後修改時間: 2023-02-02 17:02:22 - #16 [沉默的膏蟹], 23-02-02 11:55唔係built-in ,平平地用 多田/樂信/櫻花 都ok.
- #15 [anthlai], 23-02-02 10:19#10 米話唔煩,之前用Simpa 不夠一年個銅芯不能拆出來清潔,叫煤氣公司上來搞换新要5舊水,换左半年又出現同樣問題,叫師傅上來搞佢話最好换左個爐,最後長細研究後换左电磁爐快樂使用一年了。
- #14 [alexanderkoo], 23-02-02 10:011kWh(1 unit of electricity)=3.6MJ(unit for town gas as on bill) Can work out the energy cost. But must include efficiency of different units, induction Vs gas.
- #13 [patrick88], 23-02-02 09:49煤氣公司買蜘蛛絲, MIJ, 吾駛煩
最後修改時間: 2023-02-02 09:50:12 - #12 [93949394], 23-02-02 09:42aeon 福祿壽有多田, 順手換埋部雪櫃8千有找
而無論 "TGC" 或 "簡栢" 煮食爐, 不同形號的產地也有不同 (e.g. 大陸, 越南, 台灣, 日本). 通常日本造的形號價錢較貴.
用緊一個"簡栢" 煮食爐(日本造), 已有六年, 完全運作正常.
另外用緊一個 Panasonic 煮食爐己有三十年, 也是運作正常, 也是日本造.
最後修改時間: 2023-02-03 21:19:32
