- #7 [沉默的膏蟹], 21-07-05 09:23電工師傅裝抽氣扇會幫你換埋玻璃同開窿,裝抽氣扇二、三百,換玻璃二、三百, 裝抽氣扇外開多個窿未必收你錢。
- #6 [alexanderkoo], 21-07-05 09:16Very few c- Fu can cut round openings in situ. Need to take to glass shop. So, better prepare one in advance. But how without taking down?
Two extraction devices, competing for air if used at the same time. Can use cooking range alone(inclined type is better if using induction cooker) and open the kitchen door and living room window for fresh air intake. To complete air circulation path.
最後修改時間: 2021-07-05 09:23:40 - #5 [wah1080], 21-07-05 09:16#3
請教如你所說拆玻璃,使唔使將成個鋁窗拆落來呢? 呢種鋁窗如果成個拆出來,好似要拆除同安裝窩釘. 我無經驗同無工具做得到. 不過拆同裝抽氣扇我應該應付得到的.
最後修改時間: 2021-07-05 09:18:13 -
- #4 [V.C], 21-07-05 09:10要揾師傅會拆開鋁框攞塊玻璃出嚟,跟住度好尺寸界玻璃再裝返上去,工序消耗時間。
- #3 [new68u], 21-07-05 09:05如果係我會買塊鋁板開定抽氣扇洞同5吋喉洞,然後拆抽氣扇,拆玻璃,裝鋁板,裝抽氣扇裝喉。
- #2 [alexanderkoo], 21-07-05 09:04I believe that very few C-fu's are having interest on small job. They are indulged in window inspection and repair. Daily routine, just replace rivets with high reward. Being pampered for low skill. Better replace the glass by acrylic sheet of same thickness. Otherwise, it can break.
There is exemption for village house of 3 storey high, no need for window inspection. Possibly, similar for repair work. Still need to check integrity of rivets by your own. Mine were self-taping screws.
Aluminium sheet is also fine but hard to core the openings. For acrylic sheet, can ask the shop to do so. I modify my AC but still using plastic casing, easier to work with.
最後修改時間: 2021-07-05 09:13:02 - #1 [wah1080], 21-07-05 08:56想將呢個窗由原來只有一個抽氣扇改為一個抽氣扇加多一個5寸排氣喉.(並排為左邊抽氣扇,右邊排氣喉出口)
請問宜家法例係咪要由有屋宇署註冊為認可資格人士來做呢?
呢D小工程, 我應該係去搵一般五金水電工程公司做, 定係去鋁窗工程公司, 定係去專做玻璃嘅店鋪呢?
謝謝
最後修改時間: 2021-07-05 08:57:15 - 返回 ...
