- #18 [tst1800], 22-06-06 11:47Amazon 買 P2, 連運費 HK$19K, 抵呀.
- #17 [tst1800], 22-06-05 12:00請問各位師兄 : Optoma P2+ / D3 跟舊款 P2 分別大嗎 ?
因為 P2+ ( HK$29K ) 比 P2 貴接近 $7,000 (外國收貨連稅)
謝謝. - #16 [winning7], 22-05-31 11:17
HDMI2.0b, HDCP2.2 (support eARC, Dolby & DTS 5.1/7.1 audio pass through)
HK$16,999
優點: Benq 投影畫汁一直都是數一數二, 入門機都有番咁上下, 真4k60 , 1080p(120/240)兼容打機模式, 減少大畫面眼花頭暈
可以 wifi 連接串流
缺點: 不是地投放前面, 唔想淨用機身喇叭, 就算有 eARC, 都要引條長線去番前面套音響系统或 sound bar
放房走鬼式個人空間打機睇戲...就算次次放條長 hdmi 線係地我都覺得問題不大
但放廳全家人行來行去咁就唔知點處理.....
最後修改時間: 2022-05-31 11:37:10 -
- #15 [Philippe], 22-05-31 07:452,500,000 : 1 咁誇張既一定係Full on/off對比度,絶對冇意思.部機推到盡全白全黑畫面一定唔睇得.
- #14 [alexanderkoo], 22-05-31 07:251080p is still ok, depending on budget especially for novice but must be 3 LCD for color rendering. 4k ones are mostly pixel shift and native 4k one cost you a fortune.
UHD blu ray player can select 1080p output as well. Disc is also upscaling, not genuine 4k. Fake Vs fake.
最後修改時間: 2022-05-31 07:25:30 - #13 [ken311], 22-05-31 04:42Epson EF12 is 1080P projector..... it just support 4k input...
- #12 [T.K.T], 22-05-30 18:49
- #11 [T.K.T], 22-05-30 18:43
- #10 [T.K.T], 22-05-30 18:42
講開又講,全世界大部分網頁都標部 Epson EF-12 成 2,500,000 : 1 對比度(有無咁勁呀,LS-12000 旗艦型號技術下放咩!?),只係一個台灣網站咁有公義標返做 25,000 : 1 (其它網繼續張錯就錯) ,部 EF-12 只係 $7k 多的入門機,機主不妨都睇睇,但差不多規格的國產機只係$5k左右,貴兩千幾買 Epson 「貼牌」,值得與否自行決定……
最後修改時間: 2022-05-30 18:50:20 - #9 [tst1800], 22-05-30 18:15金雞廣場23樓 : xxx way. 謝謝師兄
- #8 [T.K.T], 22-05-30 10:23
入門上金雞23F啦,HiViHK 未必太合適,我前幾日先陪個 friend 睇完堆5k以下機型,結論係都玩得過 - #7 [tst1800], 22-05-30 01:26因為要過老婆這一關, 所以一定要有同類品實物畀到佢睇.
謝謝各位師兄以上介紹, 不是英國, 是溫哥華, 會研究研究, 謝謝. - #6 [Joeyd], 22-05-29 22:14Q知, 但可以睇圖自己衡量。
https://camelcamelcamel.com/product/B08FBNDGBK
50蚊寄香港真係抵運。哈哈。
最後修改時間: 2022-05-29 22:23:50 - #5 [老鼠仔], 22-05-29 22:09Optoma CinemaX P2 White Smart 4K UHD Laser Projector for Home Theater | 3000 Lumens Superior Image with Laser & 6-Segment Color Wheel | Ultra-Short Throw | Built-in Soundbar | Works w/ Alexa & Google https://www.amazon.com/dp/B08FBNDGBK/ref=cm_sw_r_apan_i_FJAJ12TWQJQNNFKK0F0J?_encoding=UTF8&psc=1
唔知仲會唔會再減? - #4 [Joeyd], 22-05-29 21:02
- #3 [10001club], 22-05-29 20:53有幾間都在灣仔, 上網可以搵到.
- #2 [kk6666], 22-05-29 14:47
- #1 [tst1800], 22-05-29 14:17入門初哥, 會放在 13 x 15尺 空間 (外國).
因為不想掛天光花及拉線, 希望由下而上的款式 ( 是不是叫「短投」? 即是附圖).
睇過好似 Epson, BenQ, Optoma 比較多選擇 (?)
香港有邊幾間陳列室會比較多參考 ? 勞煩各位. 謝謝. - 返回 ...
