- #406 [Kenny], 19-07-22 21:02London is truly beautiful ^_^.
- #405 [city_man], 19-07-22 20:50
- #404 [city_man], 19-07-22 20:47
- #403 [city_man], 19-07-22 14:28飲啤酒,食生果
- #402 [rumorguy], 19-07-22 14:26日日都有炸薯條,牛排......, 我而家上下口唇都有粒痱滋了!omg!
英國London有乜清熱氣的食物飲品呀! - #401 [rumorguy], 19-07-22 06:24我在一倫敦路邊一間小店找到了cable, 唔該曬師兄先!
- #400 [Drhandguns], 19-07-22 06:08揾間Argos基本上乜都買到。
- #399 [2628939], 19-07-21 19:24#397
補充,有comment話:
This item is fitted with a 3amp fuse which is not suitable for a kettle which requires a 13amp. Fuse - #398 [rumorguy], 19-07-21 19:04thanks information!
- #397 [2628939], 19-07-21 18:36#387
可以EBAY買,寄去酒店,一定要揾speed寄出,平日通常第二日收到,如果standard寄要隔日收。
例如呢個星期二應該有,都係£3:
https://www.ebay.co.uk/itm/392282988219
如果附近有poundland亦可以望下,可能有。
最後修改時間: 2019-07-21 18:36:50 - #396 [hnm], 19-07-21 15:19Think your London Pass has expired already, but you can try call their support team (020 7293 0972) after 10:30am this morning, explain you set the wrong period by mistake & ask them to re-set.
- #395 [rumorguy], 19-07-21 15:06我諗住星期一先至開始用London pass,現在好擔心..! ! !
any c hing知道是否未啟動?
ps. 因為我嚟咗倫敦真係未用嗰張卡ga!
many thanks...
最後修改時間: 2019-07-21 15:06:57 - #394 [rumorguy], 19-07-21 15:02今日星期日,未知去邊,市集已經行了,倫敦卡下星期一先用,(買了6天)
但想請教:
小弟買了倫敦卡, 想問下係咪去第一個景點,QR code 掃了之後,先至會開通這張卡?
ps. 因為我唔小心上網買卡時,我set咗15號至20號, 但我來咗英國直至現在都未開始用張卡的, 旦沈日收到email訊息,佢話我張卡快到期了!
但我見當時收到Email嗰個order confirmation有寫住, 當你去第一個景點, 素描左卡個QR Code 倫敦卡先至會啟動的。 - #393 [rumorguy], 19-07-21 14:53要打邊爐?
系呀!所以先至要買返條cable。 - #392 [happyboy], 19-07-21 07:27#386
Thx - #391 [skyliner], 19-07-21 07:05樓主要打邊爐?
- #390 [rumorguy], 19-07-21 06:48問過酒店佢地話冇呢啲cable!
- #389 [fotheringay], 19-07-21 06:02為何不問酒店借呢? 他們甚至可能比條spare過你。
- #388 [simpleman], 19-07-21 04:10
- #387 [rumorguy], 19-07-21 03:35諗住自己煮下嘢食,但係漏咗條電線再之前間酒店。
請問倫敦(King'sCross underground)附近,邊度地方可以買到呢啲電腦線?photo attached,Thank you
ps. 好不容易找到有一間有,但係要十元英磅!!too expensive
最後修改時間: 2019-07-21 03:40:24 - 下一頁 (4 of 24)
