- #20 [alexanderkoo], 22-08-11 12:36
- #19 [謝x庭], 22-08-11 11:05邊度仲有R22雪種賣?
想自己整部R22窗口式變頻冷氣機 - #18 [alexanderkoo], 22-08-11 09:11New refrigerant type means more development fees. Usually less cool, maybe due to AC compromised design per se, not confined to newer refrigerant which is so-called selling point.
R22 split unit (also heat pump) is available in China but not window unit. Easy to work with and maintain. -
- #17 [bearman], 22-08-10 23:17請問格力邊個型號?幾錢?thx
- #16 [沉默的膏蟹], 22-08-10 17:38張leaflet
- #15 [Sharing], 22-08-10 16:41真土冷氣 ....睇到哩個廣告, 跟住有d反胃
最後修改時間: 2022-08-10 16:42:06 - #14 [bt99], 22-08-10 16:33變頻機貴咁多,係因為比舊款定頻機結構複雜,同用乜雪種關係唔大,過得十年八載技術再成熟啲,高市場佔有率時,話唔定都會跌到千零蚊有部。。
- #13 [93949394], 22-08-10 14:57以前R22機鬼咁平,千幾蚊就有1部,之後
- #12 [rickywongwwk], 22-08-10 12:16我買咗格力最新個部r32 窗口機
- #11 [alexanderkoo], 22-08-10 09:50Very deep, not exactly drop in replacement for existing fixed speed unit. Anyway, c fu would take away existing framework even it matches,to earn money. Free rubber mat offered to silence the noise as caused by rain.
Can go for window split unit, possibly 1000-2000 more. Most brands are of grade 3 or 4 but General which is Grade 1. Durability, like tossing a dice.
最後修改時間: 2022-08-10 09:50:37 - #10 [alexanderkoo], 22-08-10 05:49Not too useful except burning money.(not even $2000 CV which can't meet the budget) The product is simply pacifying someone who cannot install split unit which has longer life span but more problematic.
Whirlpool was the cheapest (Gree OEM), maybe price has escalated.
最後修改時間: 2022-08-10 05:51:24 - #9 [呀金], 22-08-10 00:51咁似黎瑞恩?
- #8 [大隻仔], 22-08-09 22:56
近期買冷氣機當然係要買珍寶冷氣啦,你睇吓佢個廣告紅到爆炸⋯⋯
- #7 [mhl], 22-08-09 22:30
美的R32變頻淨冷窗口式冷氣機
- #6 [Sharing], 22-08-09 18:58格力 very good !!
- #5 [phil.ng], 22-08-09 18:54十一月到丶剛可用暖氣丶正呀
- #4 [沉默的膏蟹], 22-08-09 17:57樂聲冷暖,而家訂得嚟貨到都可能入冬,剛剛好。
最後修改時間: 2022-08-09 17:58:49 - #3 [林菲], 22-08-09 17:399月喇
出年先
呢啲帖應該屬5月帖。 - #2 [mrbeansr], 22-08-09 17:38平價, 格力, OEM 很多以前名牌
貴價 panasonic, hitachi - #1 [cl8390], 22-08-09 16:471 - 1.5 匹,有好介紹嗎?
Inverter fed compressor is different from fixed speed compressor.
最後修改時間: 2022-08-11 12:38:14
