- #173 [一一], 19-06-09 14:15我架小布性能上衹係將50齒大餅換左44齒大餅,其他都係外觀野
- #172 [cello], 19-06-09 13:40改左油掣,波腳,坐管,前後 避震,等等。
- #171 [rover901], 19-06-09 13:27夏天真係唔好夾硬來
- #170 [cello], 19-06-09 13:22我冬天先做到,夏天未必得?
- #169 [rover901], 19-06-09 13:20Cello 兄你架birdy好企理,換左咩brake?
其實我都打算搞下部Birdy
可能先換呔,再上套105 嘅11速,但要換hub先
最後修改時間: 2019-06-09 13:22:20 - #168 [rover901], 19-06-09 13:15你keep 到均速30, fit 過我好多, 我踩406嘅大行都唔得,踩birdy3 355原裝呔仲慢
我要勤力D操番先得 - #167 [cello], 19-06-09 13:09我都係踩約3O公哩
- #166 [rover901], 19-06-09 12:34小弟體力越來越差。隔離post 師兄下下三四十KM/h, 我依家keep 25均速都索哂氣。所以都係樂天知命,只能享受20km/h龜速巡航而矣,反而得閒搞下架老爺大行,另類樂趣 :)
改完seatpost, 仲想搞個頭擔。
最後修改時間: 2019-06-09 12:38:34 - #165 [rover901], 19-06-09 12:25Thanks Spyder Hing :)
- #164 [spyder], 19-06-09 12:23rover 兄,祝早日康復。
- #163 [rover901], 19-06-09 12:19重磅回歸,換左樣人人悪評的Litepro carbon seatpost
最後修改時間: 2019-06-09 12:25:10 - #162 [rover901], 19-06-09 12:18因腰椎突出復發,好耐無踩
- #161 [rover901], 18-07-18 23:56thanks for your advice :)
I will test the new stem carefully
I am super overweight, I must take extra cautious, luckily I dont "swing" or standup these days :) - #160 [Joeyd], 18-07-18 23:34#159 這種stem當你大力向下壓時尤其企起身踩時,有機會鬆。
我部都係尼種stem加上我人超重,我唯有就住黎踩,好少企身踩同唔會好似MTB咁搖車。 - #159 [rover901], 18-07-18 22:48The bike now is very responsive to ride, maybe the headtube/handlebar is stronger and lighter than the original. This make the turning more direct and fast.
But the new headtube does bring me a problem. It is about 345- 350mm from handle bar to its base. which is about 15 - 20mm longer than the original headtube. By its angle, the handlebar to seat distance shortened. And my brooks seat was already set to the far back.
So I have to extend the distance betweeen seat and handle bar. The easy way, is handlebar extender.
I found this in taobao, 25.4mm to 31.8mm, whihc will fit the new Longto handle bar (31.8mm). And I bought also a adaptor from 25.4 to 31.8, which is for the 31.8 clamp of the longto headtube:
This is how i looks after installation
Will test drive tomorrow
最後修改時間: 2018-07-18 23:00:38 - #158 [rover901], 18-07-18 22:35Then the head tube. After the installing the ergon, the inner folded head tube cant fold due to the Ergon's shape. And the original Dahon head tube is ugly. So I search for a one-piece tube, and finally got the Longto head tube, I dont know why, its expensive for a taobao goods, and I dont even know the shop. Luckily, the item arrived without scratch. BUT, it was longer than I expected (2cm) and came with only 1 fixing screw.....(there should be two), reflected to the seller but never reply. TAOBAO!
Here is the latest look. With Brooks B67S seat (I bought for my wife but she didnt like it) and brooks seat bag.
More to come.....
最後修改時間: 2018-07-18 22:40:28 - #157 [rover901], 18-07-18 19:14since the last modification, the Dahon covered some miles without further mod.
But a few things developed problems to me, first the handle. I had broken my wrist when I was young, it is easy to get painful whenever the wrist is under pressure. So, I changed the handle to Ergon. Problem solved.
And the pedal. The Green pedal is very big, I bought for my MTB a few years back, put it on the Dahon caused some problem, first, it made the bike big when folded. and the rusted screws always scratch my legs, so I changed them to a pair of removable MKS. Problem solved.
More to come.....
最後修改時間: 2018-07-18 19:16:17 - #156 [dttmtong], 18-07-16 18:07大家可以留意下我張相,RX-5 個羊把把手位比一般平把前好多,買時記得試清楚個 reach, 會唔會扒到好辛苦
- #155 [rover901], 18-07-16 16:55我唔計十一歲果陣架GT performance BMX(山寨版), 我正式第一架車係Giant VT, 係雲鵬仲做緊街坊生意果陣時強哥幫我砌嘅。架車入山好堅,可惜我手車屎。車悪過人嘅最佳演繹
- #154 [rover901], 18-07-16 16:49好靚仔的RX5
- 下一頁 (3 of 11)
