- #85 [joey], 21-03-03 15:19
- #84 [alexanderkoo], 21-03-03 14:04Working principle is about the same, handcuff blocking the blood vessel and measures the rise in pressure. However, MIJ products may have better electronics for higher repeatability(not exactly accuracy) giving more meaningful trend over a longer period, more reliable components.
- #83 [vaio], 21-03-03 14:02#85
咁比$50 check吓有冇問題其實都好平架喇。話晒都用咗6年多
吓吓就買新,咪又製做一件垃圾
睇次醫生,去公立醫院都唔只$50啦
最後修改時間: 2021-03-03 14:03:11 -
- #82 [dennis815], 21-03-03 13:57Check 血壓計都要$50
重未計車費同放假
買個全新水貨算,都係四五百
最後修改時間: 2021-03-03 14:00:02 - #81 [bankguy], 21-03-03 13:01我試過帶自己血壓計去睇醫生,即場對照水銀嘅數值。
- #80 [呀金], 21-03-03 12:55其實血壓計唔一定要非常凖,因為血壓本身變化好大,而家仍然有醫生用水銀柱血壓計加肉眼量度。
- #79 [bankguy], 21-03-03 11:20White Coat Effect.
- #78 [tonywong], 21-03-03 11:16去到診所量度, 高一些, 都好正常
- #77 [bankguy], 21-03-03 11:12I use two blood pressure monitors to cross check each other when in doubt.
I recently bought a Omron HEM-7600T, $1399 at Apita, $1050 at Sogo and $940 at Price.com shop. All the same thing distributed by HK agent. Of course I bought from Price.com.
最後修改時間: 2021-03-03 11:15:15 - #76 [Chia], 21-03-03 11:05
- #75 [vaio], 21-03-03 10:49剛剛打去Omron客服問過,血壓計只可能check合唔合標準,收費$50
但因為JPN1太舊款已冇零件整
咁唯有試吓攞去check,如果真係唔準就買過部啦。
最後修改時間: 2021-03-03 10:52:35 - #74 [alexanderkoo], 21-03-03 10:47Almost impossible. A calibrator should be at least 10 times more accurate, besides, too expensive for the work. Use comparison method with the mercury manometer from the doctor. If in doubt, buy a new one. My AND bought form UK amazon was less than $200. Surprised?
- #73 [vaio], 21-03-03 10:27我家人都係用JPN1,不過最近佢去醫院覆診,醫生叫佢攞佢用緊嘅JPN1去做比較,發覺原來比醫院的低咗1X度
想請問Omron有冇調節血壓計嘅服務?
因為我響FB inbox去問,幾日都唔覆我。 - #72 [patrick88], 20-09-02 22:42用緊 JPN1, 幾年前買, made in Japan, $6xx
最後修改時間: 2020-09-02 22:42:41 - #71 [tonywong], 20-09-02 11:02#31
買了兩年, 今日先拿來放在公司用, 細細隻 - #70 [41450686], 20-09-02 10:15一定買有藍牙的,方便好多
- #69 [綠Y], 20-09-02 09:49買左7600T比阿媽,唯一唔好d數字跳得好快,佢唔係每次都睇得抄得切
最後修改時間: 2020-09-02 09:49:27 - #68 [i-walker], 20-09-02 09:17另一部係 7280T, 但搵唔到依家賣幾錢及邊度有得賣?
- #67 [i-walker], 20-09-02 09:15初步睇啱依兩部,貪佢有 app 可以很方便地監察每日的血壓,其中一部係 7600T
- #66 [Krell], 20-09-01 20:17#65
As you have a patient at home as you mentioned, you should know very well what kind of life style is needed. Common sense. Don’t argue for argue’s sake.
最後修改時間: 2020-09-01 20:18:33 - 下一頁 (4 of 8)
已經踩咗幾個30分鐘以上健身單車,都冇乜大改善
各位通常有乜方法減壓? 睇過Eason醫生講唔使咁快食藥,哩個數字可再減到,都係運動減肥等
