- #45 [alexanderkoo], 19-01-23 07:18
- #44 [Neontetra], 19-01-22 19:35
電磁爐又安全,又乾淨,運作成本最平。 - #43 [DeepSea^^], 19-01-22 19:32石油氣即熱熱水器都好好用
- #42 [lym], 19-01-22 19:30但媒氣係好用。煮食火力好過電磁。熱水爐最爽,遇上天寒地凍,長開長有,係電儲水爐不能比。
- #41 [DeepSea^^], 19-01-22 19:25煤氣費是最貴的燃料費
- #40 [new68u], 19-01-22 19:11剛收煤氣賬單,未轉電磁爐前就用34度煤氣,轉之後個月用8度煤氣,真係好誇張。^^
- #39 [ef9], 18-11-23 13:46#38
P記 有 "獨立雙主線圈,使加熱更加均勻"
>>> 唔係新嘢,只係平價爐用偷雞方法,開吓熄吓扮低火力。
...個名好勁下 變頻電磁爐....哦.原來系甘 - #38 [new68u], 18-11-23 13:26好似有啲爐用內圈同外圈兩層線圈,細火內圈通電,大火內外圈通電。
- #37 [呀金], 18-11-23 13:20唔係新嘢,只係平價爐用偷雞方法,開吓熄吓扮低火力。
以煤氣爐為例,大細火任你較。如果你個爐壞咗只能大火,但你想用中火,都可以開5秒熄5秒做中火效果,想細火就開5秒熄10秒。 - #36 [ef9], 18-11-23 12:55變頻電磁爐 ....
新嘢 ??? google 過 暫得 菲仔有 崁入式未見 - #35 [new68u], 18-11-23 12:38請問呢隻corning retroflam wok同淺燒鍋掂唔掂因見佢好平。
- #34 [麥玲玲], 18-11-22 19:48#31 要變頻電磁爐, 先好用
平價爐控制火力係一開一閂, 所以好難用 - #33 [new68u], 18-11-22 19:24#30 會唔會喺煤氣單收咗?因唔係現場比的。
- #32 [呀金], 18-11-22 18:27我上次唔用煮食爐 ,煤氣公司幫我掉同封喉冇收錢。
可能個煤氣爐本身有二手價. - #31 [ernest], 18-11-22 18:23Keep返個煤氣爐啦,電磁爐好難用㗎,我淨係用佢煲水煮麵,煎唔到靚牛扒
- #30 [沉默的膏蟹], 18-11-22 17:04我上次唔用煮食爐 ,煤氣公司幫我掉同封喉冇收錢。
- #29 [new68u], 18-11-22 14:39問咗封喉收$180
- #28 [ef9], 18-11-21 23:51之前問過 吾記得 250定350
買威嗎牌 雙頭電磁爐,就免費 - #27 [cornercube], 18-11-21 21:14
- #26 [Phil.ng], 18-11-21 21:04點火器,好平
- 下一頁 (1 of 3)
Years ago, I thought the same. If you're a chef in a canteen using large wok, you would still need town gas or even diesel. For home application, got a 3000W induction stove from Taobao(with free cast iron wok), only switched to 2000W, already good enough for sauteing. There is 5000W induction stove but your cooking utensil should match, otherwise would be overheated.(so, not the higher power, the better, must consider the coil size and wok flat surface diameter)
I could install inclined type range hood with heater removal of oil (overkill for village house) to match with the induction stove, a bit nearer due to no flame.(still around 400mm from hood bottom to stove top) I burned white sage to generate white fume as smoke test.Never open the window adjacent to stove for fresh air intake, otherwise turbulent flow. Simply open the kitchen door(negative pressure inside kitchen, so no problem at all) and also keep at least one window ajar in living room for proper ventilation.
最後修改時間: 2019-01-23 07:19:38
