- #16 [mcdull], 18-07-19 14:46
- #15 [cambridge], 18-07-19 14:07No, we trust the maid
我之前post 過樓上漏咸水入我地天花,但樓上住戶仍未找到,雖然管理處已關其咸水制,但我們在旅行期間不放心,所以要同工人保持聯絡 - #14 [ecoco], 18-07-19 11:10舊零水買張10G年卡,放落舊手機,教老婆用whatsapp/skype/hangouts....etc. 見埋你樣傾,睇埋間房情況,佢咪仲放心!!
最後修改時間: 2018-07-19 11:14:06 -
- #13 [mcdull], 18-07-19 10:29#11..
how can it serve the purpose?
Just ask the maid to send a whatsapp photo at 21:30 new reports on your home TV near the time will do. (or something similar).
Or even simpler, you go check your home router to see if her cell phone is connected to the wifi. If you don't tell her, she will have no concept to intentionally leave her phone and go out. From this you can also track when she leave and when she get back. (not applicable to those ...... not even allow the maid to use the wifi network) - #12 [wajah], 18-07-19 10:21#11
佢主要肯定工人在家 - #11 [mcdull], 18-07-19 10:13>另外旅行時太太要工人每晚由香港打固網長途給自己原本的手提電話,或者太太有事要手提打給香港固網,請問是否一定要keep 張香港sim card係手機內,開漫遊,然後上網就插日本SIM card 入WiFi 旦?
1. 今時今日, 工人都應該有 wechat / whatsapp call. 硬要用手提電話, 只有漫游可靠. 或遙距飛線, which is 更麻煩. 如果係用app, 如hello 喂, king傾 呢啲其實好唔stable.. 唔重要你唔會打電話, 重要時你打唔到仲捉虫. 如果約要打出, 用 skype out / wechat out 呢啲算幾ok, 可以緊急時當電話用. 但定期收既report call, 就真係考慮用whatsapp call, facetime算啦. - #10 [Ronny33], 18-07-19 09:57上hgc買個30日$28 Hello喂啦
http://www.hgcbroadband.com/Service/helloway-tc.html
有個香港number畀你, 你出門前飛晒線過去, 係外地上到網就用佢個app打返香港
好過打漫遊, 只係打返香港個來電顯示唔係自己手機號碼 - #9 [明天的明天], 18-07-19 09:47C9唔係本身已經可以開雙咩?如果部電話 ANDROID 版本比較舊,就 DL 個雙開既 APP 用,咁就可以同時用2個 WHATSAPP
- #8 [cambridge], 18-07-19 09:07Thx
謝謝大家 - #7 [Richardw], 18-07-19 08:49Apps 就係咁方便。如果whatsapp 在你每次換sim card 或每次開機都要重新登入。這個問題就沒有發生了!
最後修改時間: 2018-07-19 09:03:09 - #6 [copen], 18-07-19 08:10你入新卡, 佢會提你換左卡, 你要唔要xxxxx?? 你ignore佢就會一切照舊. X 2
- #5 [jccwong], 18-07-19 02:31#1
最簡單在家中試下,拔走所有sim,開wifi 試下用唔用到whatsapp,
你會知道whatsapp同sim冇關係. - #4 [mcdull], 18-07-19 00:38上網同whatsapp係兩回事.
- #3 [wajah], 18-07-19 00:33^^另外用whatsapp 打電話给我,應該是用新的號碼,right?
用番舊果個號碼打比你 - #2 [michaelfan], 18-07-18 23:19只要有網絡一切照常可用的
- #1 [cambridge], 18-07-18 23:15請教各位,去日本旅行,已買了sim咭上網,如果轉了sim card, 原來的whatsapp 能否再用?群組內的人可否whatsapp 我?因為電話號碼不同。另外用whatsapp 打電話给我,應該是用新的號碼,right?
最後修改時間: 2018-07-18 23:16:21 - 返回 ...
If you find whatsapp unstable, you may want wechat / skype as backup plan.
And wechat / skype can call land line with charge.
