- #458 [0925], 24-03-06 14:42
- #457 [0925], 24-03-06 11:41new68u兄唔駛客氣,豐業好用,用幾拾年都未試過有獨立開關、燈和 socket 位出問題,我鐘意幾拾蚊買個有獨立開關2 ~ 8位拖板回來銲條 2.5mm 平方電源線再自己駁插蘇,一勞永逸。
覺得接線柱個窿唔夠深,銲穩陣好多
加個 20A EMI filter
最後修改時間: 2024-03-06 11:53:30 - #456 [new68u], 24-03-06 11:30#454 謝謝資料,剛再去望下,啲睇確實係流流地。
- #455 [alexanderkoo], 24-03-06 08:30Another toilet is having dual source of supply, salt and fresh water. Incorporation of non-returns is a must.
最後修改時間: 2024-03-06 08:30:35 - #454 [0925], 24-03-06 08:13#452 呢個 Super 唔知同 Super Star 、Winstar 有冇關係,因為呢兩隻質量好差,好多年前用過,佢用碎口料啤膠殼,脆和易爛,拆開睇銅片好薄冇彈力(應該係回收雜銅),L & N 導片距離太近,膠支架冇 "火箭脚" 一爛就短路。
- #453 [alexanderkoo], 24-03-06 08:09#451 Non-return mentioned on Taobao when buying toilet inlet valve.I am not sure whether it's necessary since the toilet seat has a tank for storage, viz break pressure, not instantaneous heating. The existing toilet flushing pipe has no such non-return. Syphon effect, not sure. But having reverse osmosis filtering unit for drinking.
- #452 [new68u], 24-03-06 07:59日本城4頭拖板$100三排,需然唔係楓葉牌,都抵過自己整。
- #451 [0925], 24-03-05 10:30#449 fresh water source is required but no problem for fresh water flushing, simply add a tee.
T 管要裝高位,落去馬桶的水管要拉長分段裝最少兩個單向閥防止來水食水被污染。 - #450 [lym], 24-03-05 10:06>>#447 冇記錯好多舊式五金舖有,一大卷鋸開要求的長度。
咁我行過問問。 Thx。 - #449 [alexanderkoo], 24-03-05 09:19Smart toilet seat (made in Korea )has been working in village house for some time. Intended to replace whole toilet but low level drain and lots of work. $1500 from Amazon (plus shipment, bought two) 115V only so would need min.800W transformer.(RMB 100) Not simply size in terms of width and length but most crucial dimension is toilet mounting hole to tank front, though the seat has a range of sliding adjustment. Otherwise, not usable if not fit at all. Of course, fresh water source is required but no problem for fresh water flushing, simply add a tee.
最後修改時間: 2024-03-05 09:26:23 - #448 [0925], 24-03-05 09:04#447 冇記錯好多舊式五金舖有,一大卷鋸開要求的長度。
Amazon US 特價。
最後修改時間: 2024-03-05 09:05:07 - #447 [lym], 24-03-05 08:49請問舊式衣櫃門路軌邊度有賣?
- #446 [0925], 24-03-04 15:32
- #445 [0925], 24-03-04 11:25
- #444 [0925], 24-03-01 10:04
- #443 [alexanderkoo], 24-02-28 09:09Bosch but comments are conflicting and confusing. Maybe related to depth of embedding.
https://www.amazon.com/Bosch-GMS-120-Digital-Multi-Scanner/dp/B004TACMZ8/ref=mp_s_a_1_1_maf_1?crid=TNGZKZF5IB2R&dib=eyJ2IjoiMSJ9.0tm_MHi0aY629NXao8kXzru90-0xjs6fg8DLTCEKygqLfYlFlGOafHT-QWmCxnKfMcKQFg9R5e7mUqbvBvq6GoYzmxMelOf4L7YBr5-Aag6kVsyN5YpqoB1dBkLFsaeZgMcqvV8Bwyin-2EOXEuKwLLHz7epov3PZmApeiDES5s3ThcKpkn71zOrU50ShhHDNcqb5Y_QC_nfejSq-5yIXA.ifcRxpVTa5KDgC-GP51lgaMfL8vtad_67Wa8bmLgMkM&dib_tag=se&keywords=bosch+cable+detector&qid=1709078853&sprefix=bosch+cable+dete%2Caps%2C434&sr=8-1#aw-udpv3-customer-reviews_feature_div - #442 [0925], 24-02-28 08:34
一縷炊煙兄,
仲用得 Hilti 的確利害!
最後修改時間: 2024-02-28 08:43:34 - #441 [alexanderkoo], 24-02-28 07:50219 but don't expect too much even for higher priced one.
- #440 [alexanderkoo], 24-02-28 07:44Can't find accurate one, many having negative feedback. Maybe the one from Bosch is slightly better. Taobao got one at $300, brand Delixi(?) Didn't buy, already got similar.
Industrial one, working on current transformer principle is a lot better. Wrap the CT on cable/pipe and induce a pulsating voltage. An earphone with sensor would pick up the signal.
Look for horizontal and vertical line along the wiring switch/socket. First observation, don't drill on the line. Secondly, use the detector as kind of comfort. Plumbing, mostly having hot water, switch on heater ant turn on faucet hot water and you can check the warmth on wall. Mark the plumbing run.
最後修改時間: 2024-02-28 07:46:05 - #439 [EF9], 24-02-28 04:53請教 有關 測牆身 電源問題
平嘅 驚佢唔準 /測唔到。
有冇啲 1千元 左右 測試可以推介下
Thx - 下一頁 (4 of 26)
"撥" 大佢
OK
最後修改時間: 2024-03-06 14:45:12
