- #470 [alexanderkoo], 24-03-25 06:19Delixi brand, not Deli.
- #469 [Ck2007], 24-03-25 06:17For room measurement thanks
- #468 [alexanderkoo], 24-03-25 06:02Laser(infra red) for room measurement or caliper? Got both.
- #467 [Ck2007], 24-03-24 23:58請問有冇底用電子尺介紹. Thanks
- #466 [ich], 24-03-18 08:55想慳錢就要自己動手拆哂舊廚櫃、地板、island table. 再鋪原木、磨平、上油.
最後修改時間: 2024-03-18 08:56:50 - #465 [alexanderkoo], 24-03-18 08:26去年買的二手30 25L還健在,$150. 顯示没有背光,很難用,以為是壞了,原來舊款是没有,買了二塊背光板,@8加條電阻,在底版5V取電,長着,可用,但不太理想,在壓缩機取電比較合理,行機才顯示,但電線較長,空間有限,背光壞了才算
最後修改時間: 2024-03-18 08:37:57 - #464 [0925], 24-03-17 03:07
- #463 [0925], 24-03-17 02:40
- #462 [alexanderkoo], 24-03-13 07:57Can be called DIY揮春? Chinese calligraphy from wife, myself no such talent.
- #461 [alexanderkoo], 24-03-13 07:51This mouse pad(designed for table )is good with bottom screw in clamp, $15 yet at comfortable hand level. Another type designed for such is $40 yet with self adhesive tape only.
最後修改時間: 2024-03-13 07:52:16 - #460 [alexanderkoo], 24-03-13 07:46Flushing water outage for three days. Redeploy a 2- way valve(taken from another shower head with Amazon shower feature)for shower/flushing selection.
- #459 [lym], 24-03-11 16:40#447 度左大細係淘記買左金屬軌。
- #458 [0925], 24-03-06 14:42個設計係要用一條有長咀的 usb-c 頭至插得入,跟機條線個咀都唔夠長 contact INT
"撥" 大佢
OK
最後修改時間: 2024-03-06 14:45:12 - #457 [0925], 24-03-06 11:41new68u兄唔駛客氣,豐業好用,用幾拾年都未試過有獨立開關、燈和 socket 位出問題,我鐘意幾拾蚊買個有獨立開關2 ~ 8位拖板回來銲條 2.5mm 平方電源線再自己駁插蘇,一勞永逸。
覺得接線柱個窿唔夠深,銲穩陣好多
加個 20A EMI filter
最後修改時間: 2024-03-06 11:53:30 - #456 [new68u], 24-03-06 11:30#454 謝謝資料,剛再去望下,啲睇確實係流流地。
- #455 [alexanderkoo], 24-03-06 08:30Another toilet is having dual source of supply, salt and fresh water. Incorporation of non-returns is a must.
最後修改時間: 2024-03-06 08:30:35 - #454 [0925], 24-03-06 08:13#452 呢個 Super 唔知同 Super Star 、Winstar 有冇關係,因為呢兩隻質量好差,好多年前用過,佢用碎口料啤膠殼,脆和易爛,拆開睇銅片好薄冇彈力(應該係回收雜銅),L & N 導片距離太近,膠支架冇 "火箭脚" 一爛就短路。
- #453 [alexanderkoo], 24-03-06 08:09#451 Non-return mentioned on Taobao when buying toilet inlet valve.I am not sure whether it's necessary since the toilet seat has a tank for storage, viz break pressure, not instantaneous heating. The existing toilet flushing pipe has no such non-return. Syphon effect, not sure. But having reverse osmosis filtering unit for drinking.
- #452 [new68u], 24-03-06 07:59日本城4頭拖板$100三排,需然唔係楓葉牌,都抵過自己整。
- #451 [0925], 24-03-05 10:30#449 fresh water source is required but no problem for fresh water flushing, simply add a tee.
T 管要裝高位,落去馬桶的水管要拉長分段裝最少兩個單向閥防止來水食水被污染。 - 下一頁 (2 of 25)
