- #41 [alexanderkoo], 19-12-09 16:56
- #40 [Nt008], 19-12-09 11:55買棕欖 洗頭水,最好系美國版,
冇就買泰國版。
洗得干淨,又頭髮柔軟。貼服。
算平宜抵用。
$20~30,1000ml,
或者日本城$13,350ml - #39 [Chia], 19-12-09 11:24頭髮要好好保護
- #38 [cornercube], 19-12-09 11:14
- #37 [Jcmbz], 19-12-09 11:08如果多頭油,有人的確係介紹勞工牌洗衣梘
同叫千萬不要用太滋潤的洗頭水 - #36 [明天的明天], 19-12-09 10:55>d洗頭水 / 護髮.. 久唔久 要轉 配方or牌子
我又真係KEEP住用同一隻牌子既話會好多頭皮........ - #35 [alexanderkoo], 19-12-09 10:52d洗頭水 / 護髮.. 久唔久 要轉 配方or牌子
Heard of such saying before. May be applicable to the ones having additives and hence toxins. Organic one should be OK yet inexpensive.
剃光咪仲好
Unnecessary due to DHT in male, premature hair loss and hence thinning. You'll find using less shampoo. In reality, retaining full hair is difficult. Hair transplant is terms of tens of thousands but shampoo is cheap, in comparison. But don't imagine shampoo alone can treat hair loss, only preventing a bit. Other factors are nutrition, stress. - #34 [Kelvinzy], 19-12-09 09:13剃光咪仲好
洗面洗頭一齊搞掂 - #33 [bb1668], 19-12-09 08:30用海鹽洗頭
- #32 [cornercube], 19-12-09 08:28離題
有 傳說
d洗頭水 / 護髮.. 久唔久 要轉 配方or牌子...
https://tinyurl.com/sblybug
https://www.hairguard.com/foods-that-cause-hair-loss/
Foods That Can Cause Hair Loss
Dairy Products
Carbonated Drinks
Sugary Cereals
Greasy Foods
google
gluten and hair loss
https://tinyurl.com/uqw96d2
最後修改時間: 2019-12-09 08:29:20 - #31 [alexanderkoo], 19-12-09 06:19While staying in hotel, get some more shampoo, basically for free. No point of going to the supermarket, but only good for thinning the hair.
Not simply cleaning effect, should be basically similar. Only kind of additives and hence accumulation of toxin. Must correct such misconception.
最後修改時間: 2019-12-09 06:19:33 - #30 [純情小花], 19-12-09 03:38用好少,男人一個 Quarter 大細己經夠。
我短頭髮,日日用一亳子咁大細,一支用足成年。
我家姐係 IBS 代理攞,平一節。Winners,Walmart 有時有貸,留意下。
最後修改時間: 2019-12-09 03:41:18 - #29 [Somonica], 19-12-09 03:18
- #28 [mcdull], 19-12-09 02:51男人短髮真係冇乜要求. 又唔係話要cheap到洗潔精. 但果啲加乜加物又唔需要. 而市面上基本都係花巧野.
基本上無矽已經夠.
johnson baby似乎都係一個唔錯選擇. - #27 [純情小花], 19-12-09 02:36卅年前,用咗專業洗頭產品,冇得返轉頭。
用過黑人頭、Joico、L'Oréal Professional,宜家用 Pureology。
利申,家姐係註冊美容師。
最後修改時間: 2019-12-09 02:36:26 - #26 [ivanlaw888], 19-12-09 01:07回到70年代?身體副偈為自己打拚搵錢作戰,點可以咁刻薄自己,PH值偏酸偏鹼都好有學問,廿零蚊大大枝比D咩你?人工連運費都未得啦,人做色素人做香料起泡劑加杰劑全部工業用嘅料比你,人食嘅奶粉都做手腳啦,真係無言
- #25 [明天的明天], 19-12-09 00:56>我係去酒店用沖涼液洗頭都得果種.
我D頭髮會硬到好似食左偉哥咁。。。。。睇黎你D髮質好好!!! - #24 [smash], 19-12-09 00:48擺喺藥房門口嗰啲我唔會買. 接受個陽光曝曬, 可能會變質. 尤其是係食物.
- #23 [smash], 19-12-09 00:46男仔短頭髮, 每次用咁少洗頭水, 點解洗頭水都要慳? 一支洗頭水有排用. 直接同皮膚有接觸, 當然要用好嘢.
用洗潔精真係搞笑, 不如直接用番梘或者番梘液重安全
最後修改時間: 2019-12-09 00:49:24 - #22 [CS168], 19-12-08 23:57
仲有樽護髪素!
永遠用不完,只有去泳池游水!
浸過泳池水漂白齊先至會用小小。^^ - 下一頁 (1 of 3)
Maybe you guys are young. Prevent hair loss is a must. Residing hairline is early symptom, followed by thinning hair at the top. Otherwise, a bald guy would look ten years older.(won't matter only if you are a billionaire)
最後修改時間: 2019-12-09 17:01:26
