- #86 [ich], 19-02-23 22:56
- #85 [city_man], 19-02-23 15:08忽然對L豬
好感大增!
雀仔也高興! - #84 [廣東十虎], 19-02-23 15:00好感動!多謝!
最後修改時間: 2019-02-23 15:00:27 -
- #83 [dominic36], 19-02-23 10:03我哋同雀仔都冇投訴!
- #82 [alexanderkoo], 19-02-23 08:38For cloth drying especially during winter, a Delonghi desiccant type dehumidifier would do a good job, with built in heater.(or KDK/Panny) Place 5 kg clothings inside a small store room(underneath staircase, sloping ceiling and hence not useful at all), dry them within 6 hours. The drawback is zeolite stone has limited life hence only for cloth drying,not space drying. Conventional dehumidifier is affected by low temp, spending most of the time in defrosting.(actually stop the machine and blow to thaw the ice)
最後修改時間: 2019-02-23 08:40:15 - #81 [堯軍], 19-02-23 08:05我用緊L豬8k/5k有半年,暫時滿意,洗嘅時候靜,但去到1400轉乾衣就點都有啲嘈。另外乾衣話就可以5kg,不過入滿5k兩個幾鐘根本焗唔乾, 只可以半量,否則要加時。而焗衫我一般只放棉質衫毛巾襪床單,所以都每次都有半機衫要「浪」乾
- #80 [ich], 19-02-23 01:48#78
我部 LG 7KG淨洗用了剛 3年。到宜家都係好靜。
我個人唔買洗衣乾衣機,感覺易壞。或者壞了其中一樣等如兩部機都唔用得。 - #79 [shektau6], 19-02-23 01:32My LG 8kg washer/dryer died due to malfunction water inlet pump 2 days after warranty expired. One can easily buy spare part from taobao and replace it if you can wait though...
- #78 [廣東十虎], 19-02-22 08:13早晨各位:我想買8~10kg大眼雞買LG定日立好呢?包埋冷凝乾衣唔洗快,6個鐘洗加乾衣最緊要靜,可否指引下唔該*Σ*
- #77 [沉默的膏蟹], 18-02-25 18:3715分鐘係洗半機,同唔太污糟只著咗一日有汗既衫。果條出水喉幾個牌子都有。
最後修改時間: 2018-02-25 18:38:22 - #76 [Nickmanwoo], 18-02-25 18:02日立Daily 60 有
但是無得縮短,一係15分鐘,太短,搞三四下都收工
但日立個隔渣Filter 設計得好
有另一條軟管可用水盤先慢慢放走污水,然後才扭出隔渣 filter, 唔會成地水
最後修改時間: 2018-02-25 18:03:38 - #75 [沉默的膏蟹], 18-02-25 17:50日立大眼雞應有個60分鐘日日洗
- #74 [Japhetj], 18-02-25 17:23點解唔出窄身大眼雞俾我呢啲焗用歐式機嘅客 >_<
- #73 [city_man], 18-02-25 16:1015分鐘太短 ...x 2
so quick .... - #72 [Nickmanwoo], 18-02-25 15:56過年前用咗7年多金章 7kg 1200轉打柴 (2010年買$5200)
買咗日立 BD-W80AV 8Kg 1000轉 直驅
$3900包送安裝,拆運舊機
優點
比較靜一半声
LCD Display 字夠大(橙色字,但我覺得綠色字順眼)
有 User memory
安全鎖夠快,洗完停機即開
水位比較高,見到少少水洗衫,舊金章個部太少水,老細嘈好似無咩水,有時間洗吸水衫要人手加水(吹漲)
缺點
快洗 Mode 15分鐘太短,應該做30分鐘左右
Buzzer 細声咗少少
應該買1200轉,貴多$900
P.S. 日立不銹鋼洗衣桶裝咗幾個平衡水箱, 即係滾動它的時候會有水聲以為有積水 - #71 [Hifi-Bowling], 18-02-21 11:18How much is a 8 kg washer/dryer ?
- #70 [沉默的膏蟹], 18-02-20 18:17即係都係日式機,左右攪係會互相痴毛。
- #69 [swcheung60], 18-02-20 17:33我有親戚用Miexx(發展商交樓標準),2年前攝咗銀仔,維修費2千幾蚊(已過保用期)
- #68 [swcheung60], 18-02-20 16:53#67
下次會試下 把毛織物及有毛的 分開洗
呢部LX唔貴 如果能用5年已收貨了 - #67 [Kelvinzy], 18-02-20 16:44標準即係for一般衣物,包括棉制品
毛織品應該用“羊毛”mode,因為毛織品洗衣需要柔和的多,又唔可以擰來擰去,轉速也要慢,同埋要用羊毛專用洗衣液
我部白朗都係咁
最後修改時間: 2018-02-20 16:45:39 - 下一頁 (1 of 5)
laundry變做aviary?!
