- #368 [ronnieng], 22-08-06 16:25
- #367 [Dlbf], 22-08-06 16:12而家啲官真係唔使用腦。
- #366 [敗家仔], 22-08-06 16:03係咪自顧同個場地有過失比人文事追究有乜嘢關係?有雇主就雇主先賠,雇主搵番場地,都係同一個責任
- #365 [ronnieng], 22-08-06 15:59勞福局長咁柒話調查「自僱人士係咪真自僱」,真係捉蟲入屎忽。
- #364 [ronnieng], 22-08-06 12:12兩個舞蹈員仲冇注射到疫苗。
- #363 [敗家仔], 22-08-06 12:12上演反正我信了
- #362 [joey], 22-08-06 12:01金屬疲勞 ?
不如講兩個舞蹈員黑仔唔好彩啦 , ~完~ - #361 [winning7], 22-08-06 11:53大國邏輯...最後都係推到2舞蹈員疲勞...再控制全部表演者, 上訪家人....再出埋白衣人拳打腳踢
- #360 [lym], 22-08-06 11:49腥趕人日日對住垃圾疲吾疲勞?
- #359 [oystercake1997], 22-08-06 10:57D飛機使用到一段時就會檢查d join 位有無金屬疲勞。
- #358 [alexanderkoo], 22-08-06 09:54Avoid overloading or else injury not covered by insurance. In HK, old design is having overspeed mechanical device to hold the cabin onto the side rails but slow acting. New additional safety standard is to clip the rope at lift room in case of free fall.(broken wire at the counterweight portion or loosened fixation at counterweight) My building has just upgraded the lift. Possibly such safety device not found in China.
In case of service suspension, don't attempt to force open the door. Otherwise, head can be chopped off if restarts.(happened before) Tell your family, too. Stay inside the lift is safe, call for help. Fire department will attend first so won't take long, followed by lift company.
最後修改時間: 2022-08-06 10:03:16 - #357 [hnm], 22-08-06 09:33我喺強國搭電梯都好驚,尤其普通民房/低級寫字樓,chok下chok下個心都離埋。
- #356 [Thanatos], 22-08-06 08:54疲勞呢兩個字,以後可以套用喺所有豆腐渣身上
不如簡單啲叫做豆腐渣疲勞 - #355 [pharm], 22-08-06 08:29梗係金屬嘅錯啦,冇人疏忽,判條鐵10轆8轆。外國貨就強烈蜆扎。
之後收幾百萬專家痿完會研究報告以後要加多條。
最後修改時間: 2022-08-06 08:33:05 - #354 [olddude], 22-08-06 08:28一早講咗搞完一場大龍鳳結果就會係咁
- #353 [new68u], 22-08-06 08:14掂哂,又冇人要負責。
司徒家成:金屬疲勞不一定涉及人為
與會的香港工程師學會代表司徒家成表示,金屬疲勞有很多原因,包括長時間耗損,以及即時操作上出現問題,都有機會導致鋼索出現金屬疲勞而斷裂,強調不一定是人為因素導致金屬疲勞,仍然要做深入檢驗,以確定導致鋼索斷裂的原因。」 - #352 [ronnieng], 22-08-05 23:33不如諗下條綱索係咪畀人換咗包。就好似啲頂包認罪咁樣。
關鍵問題係唔應該兩條綱纜咁少,睇下啲電梯就明。
最後修改時間: 2022-08-05 23:35:09 - #351 [lym], 22-08-05 23:30其實條綱索係未被屈打成焦?
- #350 [morningsir2000], 22-08-05 23:28做工程嘅香港人好醒架,唔好諗住過到骨。
快能啲公佈邊間公司做 ? 邊條友装 ? 要快....
最後修改時間: 2022-08-05 23:30:15 - #349 [lym], 22-08-05 23:22天上D飛機日日飛好疲勞,吾見跌晒落黎?
最後修改時間: 2022-08-05 23:22:36 - 下一頁 (7 of 25)
最後修改時間: 2022-08-06 16:26:12
