- #10 [ovator], 21-05-16 12:05
- #9 [Joeyd], 21-05-15 23:07
https://shop.hornington.com/products?query=Intehill
https://www.cosmictechnologyhk.com/category/27027
最後修改時間: 2021-05-15 23:10:09 - #8 [ovator], 21-05-15 23:04
#5<thank you. I didn't know ipad pro is compitable with win 20.
- #7 [Chan@review33], 21-05-15 21:58
- #6 [ovator], 21-05-15 21:51I have a ipad pro, but how can I connect it with my Win 10 laptop ?
can different OS connect ? - #5 [Chan@review33], 21-05-15 20:55買個ipad pro 用托架
搞咁複雜 - #4 [cornercube], 21-05-15 20:11diy try
用1mm厚不鏽鋼片(size big enough holding portable mon & drill holes adapt to vesa ),
燒焊 4件薄鐵介子去不鏽鋼片(介子e.g.dia 20mm etc.correspond to 強力攝石 .)
便攜芒 膠水黐 4粒強力攝石
etc
又或者
便攜芒 黐 鐵介子
不鏽鋼片 黐 攝石
最後修改時間: 2021-05-15 20:21:35 - #3 [Joeyd], 21-05-15 19:47有果個mount 就唔夠便攜啦
- #2 [cornercube], 21-05-15 19:41或要diy
google
portable monitor with vesa mount
tinyurl.com/5bpk79wy - #1 [ovator], 21-05-15 19:21請問有冇便攜mon 牌子可以在室內時用standard mon mount(4 screws square type)?
Thanks - 返回 ...
You have helped me save $1,500. Thank you so much!
https://zh.duetdisplay.com/
