- #18 [Kingcannon], 21-06-06 19:34淘寶訂咗54 mm,但有啲大,自己改裝,用錘仔揼細啲,用角磨機削一半條邊,而家部機可以再用了
- #17 [Donhenley], 21-04-22 00:17唔該晒師兄?,我去睇吓,謝謝你
- #16 [Kelvinzy], 21-04-21 09:16
- #15 [Kelvinzy], 21-04-21 09:15
- #14 [Kelvinzy], 21-04-21 09:14
- #13 [Donhenley], 21-04-21 02:00Krups 舊型號。唔該晒
- #12 [Kelvinzy], 21-04-14 16:07樓主
你講清楚你部咖啡機型號
我幫你搵 - #11 [Donhenley], 21-04-13 23:53喺淘寶訂咗 58mm,唔啱,太大 ??
- #10 [hahayanyan], 21-03-21 22:03
- #9 [hahayanyan], 21-03-21 18:48如果咖啡粉冇過量, 喺呢個情況之 水平與否 一個觀感問題
Yes 咖啡粉冇過量, have a 線之下唔平都冇問題㗎
因為這種pressurized filter. Will hold the pressure until it reach let's say 9bar.., then coffee start to come through those holes
Use tamper with pressized filter 亦都係一種玩法, but not necessary ...NEED THAT FOR OVERDOES HAHA... AS MORE COFFEE richer taste , then need to tamp it little bit to keep the height ..etc.., ohterwise may be hard to put the handle onto the machine etc..
Of coz with unpressureized filter, we need to tamp hard to get that brewing pressure
最後修改時間: 2021-03-21 18:53:11 - #8 [ich], 21-03-21 16:41#6,#7
好奇一問:
乜無論是否pressurized 都要用tamper? 唔用tamper嗰面唔平都得? - #7 [hahayanyan], 21-03-21 12:06look closer..your basket is pressurized
- #6 [hahayanyan], 21-03-21 10:54#4
That basket can hold about 10 grams of coffee
If u goinG to make double expresso, u need a basket can hold 15 to 18 grams
If u going to make a extra large cup. U may need a basket can hold 10 to 21 grams etc..
Taobao basket is good enough
There is pressurized (u shall need a tamper) and unpressurized basket (u shall not need a tamper) too
最後修改時間: 2021-03-21 10:56:20 - #5 [ich], 21-03-21 10:34#4
你呢個係58mm wor.....TB多得很.順便淘埋tamper,Knockbox 之類, 平靚正. - #4 [Donhenley], 21-03-21 08:24謝謝師兄。問咗淘寶,叫我訂51mm,真係唔知啱唔啱
- #3 [ich], 21-03-20 12:09#1
Krups 唔止出過一款expresso 機.
只要買上面最闊位置唧size filter就用得.通常入門、平價機係46mm, 貴、專業機用58mm - #2 [beginnerbilly], 21-03-20 09:56
- #1 [Donhenley], 21-03-20 08:42唔知各位師兄仲有冇呢款espresso 機嘅咖啡濾網?
Thanks - 返回 ...
