- #24 [alexanderkoo], 21-11-28 06:10M6 appears small in dia. , may be M8, not commonly found in metal shops but Duck st. For longer length, got to buy from Taobao, already bought a few. (very common in China)
- #23 [alliance0621], 21-11-27 20:57唔該晒咁多位, 麻煩大家真係唔好意思,電視冇搬出黎平放係地下所以冇睇到(因為地方太細,搬出入好大動作)就以為同之前二部一樣,現在清楚了,星期一去買正確size既螺絲問題應該可以解決 thanks everyone.
- #22 [0925], 21-11-27 19:22
- #21 [MinnaNoTabo], 21-11-27 19:13你禁條link睇下啦!人地果個就係NB,
你咁驚,就親身出去鴨記睇實物,都係賣$1XX-2XX左右
https://www.facebook.com/107393257420680/posts/155045635988775/ - #20 [cornercube], 21-11-27 19:13>>#17....咁粗嘅螺絲...五金舖?
咁粗嘅螺絲 五金舖:
https://goo.gl/maps/vApuNegf9ZmjdnLPA
https://goo.gl/maps/36BbYJN41V3pymdc7
https://goo.gl/maps/3CKvXTpGeisVrzh9A - #19 [wah1080], 21-11-27 19:08#11 , #18 張圖其實好清楚. 樓主諗清楚如果唔加wall mount adaptor 得唔得.
- #18 [0925], 21-11-27 19:00樓主咁多疑,做事卻不求甚解,如果係女人又醜樣,同毒鵝柒七漆可能有得 fight。
#11 的資料:
C = 43 ~ 45mm
最後修改時間: 2021-11-27 19:06:46 - #17 [alliance0621], 21-11-27 18:53#15/16 兩位師兄, 剛才將電視平放在地下然後照清楚果然有” 紋” 係入面不過非常之深同埋個螺絲位好大(差唔多接近一個cm, 有冇咁長咁深同咁粗嘅螺絲呢? (唔通就係M8螺絲就係咁粗? 因為跟腳架個D螺絲太幼根本入落去好似牙籤咁, 鴨記有冇啲咁粗嘅螺絲或者普通五金舖?
請指教一下 - #16 [S.Chan], 21-11-27 18:16螺絲紋會唔會喺入d. 揾粒 長d嘅M8試吓。
最後修改時間: 2021-11-27 18:17:28 - #15 [沉默的膏蟹], 21-11-27 17:25有冇用電筒照到底?
- #14 [alliance0621], 21-11-27 16:43背後的圓形孔見附圖(唔好意思打擾哂咁多位師兄幫手)
最後修改時間: 2021-11-27 16:44:48 - #13 [alliance0621], 21-11-27 16:41#8 Tong C Hing
問了淘寶供應商他說不肯定是否可以加上冇貨(之後衝衝下線) 冇符
(電視機背後四個孔是圓滑的, 沒有任何螺絲紋可以入螺絲入去然後收緊的, 幾奇怪下, 唔怪之得代理話你一定要同我哋買配件同掛架先得) - #12 [alliance0621], 21-11-27 10:48多謝晒咁多位師兄, 慢慢了解一下先, 感謝各位幫忙
- #11 [stevey888], 21-11-26 00:37Why didn't you read the manual?
I read the manual of Samsung UA49RU7100J and it indicates you need a "Samsung Wall mount kit ". It consists of 4 wall mount adapters which screw into the TV and the screws that screws into the adapters, plus two strips of brackets.
https://downloadcenter.samsung.com/content/EM/201909/20190902165514741/BN68-09967A-00_UM_URU7100H_ZK_L02_190829.0.pdf
It is on page 7. - #10 [shektau6], 21-11-25 22:17Del
最後修改時間: 2021-11-25 22:19:54 - #9 [dttmtong], 21-11-25 22:10唔 sure 你係咪講緊呢個膠圈,因為我裝三星 sound bar 都有呢個問題
- #8 [dttmtong], 21-11-25 22:06唔係好明你差乜嘢螺絲
- #7 [wah1080], 21-11-25 21:16我睇user manual, 入面有提到螺絲尺寸係用M8的.
但唔知同你個架是否配合了.
https://www.samsung.com/hk_en/support/model/UA49RU7100JXZK/ - #6 [MinnaNoTabo], 21-11-25 20:56
- #5 [sbug], 21-11-25 20:53我之前用NB, 又平又好用.
