- #60 [V.C], 21-05-04 13:33
- #59 [roy41], 21-05-01 19:25多數用膠圈
鏍絲牙沒包少少水喉膠布
十年後要換,啲牙生銹會卡死 - #58 [lym], 21-05-01 18:14我懷疑支野係抄番黎。
- #57 [0925], 21-05-01 18:08大碌國人頭腦唔夠靈活,個手柄直徑和接頭應該造細啲,"啤" zinc alloy,細接頭配不同 sizes 六角頭就好用好多。
粗計: 五皮嘢起套模 + 15皮做貨,賣六拾到一佰萬,减拾皮 handling,執卅拾到陸拾萬一年。
最後修改時間: 2021-05-01 18:18:52 - #56 [lym], 21-05-01 17:18諗起岩岩換都係有點運比我鬆到D水龍頭下面個六角絲母,咁鬆左就有少少虛位比我打斜少少個舊龍頭腳,用士巴拿箝到咬住龍頭腳個入水銅喉索母。再在面盤上面用手搖個龍頭,好彩比我成隻腳從龍頭坐分開。個盤底鉗反而用不著。
最後修改時間: 2021-05-01 17:19:38 - #55 [林菲], 21-05-01 17:09Lym sir 咪借D嘢乘機爆咸:-)
- #54 [lym], 21-05-01 16:59#52 碌野全靠睇下個頭食吾食得應水龍頭個螺母。
最後修改時間: 2021-05-01 17:00:12 - #53 [alexanderkoo], 21-05-01 16:26I couldn't measure the diameter of the locknut due to congested place. Caliper is more accurate. The wrench I got from Amazon was smaller. Infrequent use, so didn't bother.
- #52 [0925], 21-05-01 14:51估唔到咁大碌,和祈求得到的有落差。
最後修改時間: 2021-05-01 14:51:52 - #51 [alexanderkoo], 21-04-25 17:11Best means is to ask your wife to find identical part and you diy.
- #50 [S.Chan], 21-04-25 14:49#49 拾爺,知道, Thanks.
- #49 [254mm], 21-04-25 14:44Re #47,要揾師傅攪,呢d 龍头而家未必配到
最後修改時間: 2021-04-25 14:46:21 - #48 [謝x庭], 21-04-25 14:36#44 用唔到,因是這隻,2粒絲母已上緊都左右搖。
- #47 [S.Chan], 21-04-25 12:27昨天收到太太 order 要攪呢個提拉式浴缸龍頭漏水問題,成三十幾年。要拆到至知,成個換選擇唔多。
最後修改時間: 2021-04-25 12:31:00 - #46 [dindunlo], 21-04-25 12:21#41
如果你個水龍頭,唔係裝喺雲石面,
而係裝喺星盤面真係冇辦法。
因為唔係水龍頭摇,而係不銹鋼盤料太薄。 - #45 [dindunlo], 21-04-25 12:18#43
就咁睇你而家嗰款都可以嘅,我呢頭五金鋪大約九十蚊貨仔。 - #44 [S.Chan], 21-04-25 12:16
- #43 [lym], 21-04-25 12:02我都想買靚D,但我度係租既,所以。。。
- #42 [dindunlo], 21-04-25 12:00#36 人工貴過龍頭,貴買平用,日本和歐洲龍頭隨時用二、三十年。
有時C9嘅思維好難理解,我有個熟客淘過浴缸排制返嚟,叫我幫佢換,我收佢工費$350.。
佢淘返嚟30蚊人仔,我都話佢自己用點解唔買個靚野。 - #41 [謝x庭], 21-04-25 11:52我都好頭痛,廚房個龍頭已上到好實,但都左右搖,有冇計?
- 下一頁 (1 of 3)
最後修改時間: 2021-05-04 13:35:17
