- #2012 [rover901], 24-05-10 16:18我估係
- #2011 [dttmtong], 24-05-10 15:24其實買都係一舊水,入貨應該係平到喊
未砌過 TA, 佢係咪其他系列都係無 bearing? - #2010 [rover901], 24-05-10 09:44仲有,兩差幾唔包啤呤都有啲孤寒
- #2009 [rover901], 24-05-10 09:43吊!原來係要上網自己睇
其實RC盒內嘅說明書係收藏嘅其中一個重點,而且睇住本說明書砌先至有feel
Team Associated 好L cheap - #2008 [dttmtong], 24-05-10 09:43唔係呀化
- #2007 [rover901], 24-05-10 09:40搵匀都唔見manual
- #2006 [rover901], 24-05-10 09:39經典金盤
- #2005 [rover901], 24-05-10 09:38好充實,
- #2004 [rover901], 24-05-10 09:35開箱
- #2003 [rover901], 24-05-10 08:37Thanks! Search 完立刻喺一間叫rcecho 訂咗
- #2002 [dttmtong], 24-05-10 07:46.
- #2001 [dttmtong], 24-05-10 07:43我見 carosell 賣 RC10cc, 送 T works bearing 的
T works 岀好多 buggy option 的 - #2000 [rover901], 24-05-10 07:38Fastest香港搵唔到,要amain 訂
Rcmart cheap bearing 竟然無出RC10 classic 版本
又唔係好想買淘寶貨,都係貴啲都要買fastest
最後修改時間: 2024-05-10 07:43:21 - #1999 [dttmtong], 24-05-10 06:29Bearing 真係好鬼貴
我踩單車人廢但器材勁,以前 Bottom Bracket 同埋 Jockey wheel 必定用 CeramicSpeed, 但係有人 test 過個 watt 數其實慳唔係好多 :p 兩粒 CeramicSpeed coated bearing for bottom bracket 可以成四仟蚊港紙
現在單車野貴到真係買唔起,我其他單車都係用台灣 bearing,貴個幾部先用 Ceramic Speed
最後修改時間: 2024-05-10 06:30:28 - #1998 [416GTA905], 24-05-10 05:21有陶瓷版本添,5x價錢,超貴
https://www.amazon.ca/FastEddy-Bearings-Compatible-Associated-Ceramic/dp/B0BCT1FMQ8
最後修改時間: 2024-05-10 05:23:49 - #1997 [416GTA905], 24-05-10 05:17閉,等陣,美帝用美製
日本製造一定公製,咁就冇法
我用過Fast Eddy,中国製造,hobby shop 老闆話QC好,好少退貨
https://www.amazon.ca/FastEddy-Bearings-Compatible-Associated-Bearing/dp/B016RHWDJA - #1996 [416GTA905], 24-05-10 04:35強烈推介 AXON X10 bearing set,日本製造,不過未見有set俾RC10,等吓一定好快有 :P
其他國內製我感覺唔到不同牌子有乜分別,就算TAMIYA 中国製Bearing都一樣,要自己再落過油先覺得正。 - #1995 [albertohassier], 24-05-10 03:07OMG.原來RC10冇跟bearing, 有冇兄弟知點配返成套。。Tks
- #1994 [albertohassier], 24-05-10 03:05OMG.原來RC10冇跟bearing, 有冇兄弟知點配返成套。。Tks
- #1993 [rover901], 24-05-09 14:04skyfly G7P 十分之抵玩,質素接近3PV/MX6, 平一截, 加上receiver 又平過Sanwa Futaba, good choice
RC10 我打算1060, Holmes 紫色有刷及亞馬遜20kg servo, Futaba 4pm + - 下一頁 (4 of 104)
