- #12 [phil.ng], 20-03-29 09:00
- #11 [phil.ng], 20-03-29 08:49Snake 有 幾個size, 普通喉買最幼丶糞就要粗點(四寸喉)
- #10 [alexanderkoo], 20-03-29 08:38Would need kind of bending radius(can't go through sharp bend), the demo was a UPVC pipe of larger dia. No more gimmicks. Now what, the magical mop with absorbing foam material, push to dry, still there.(wife almost got one) Few years ago, the mop with swivel drying tank.(can't absorb water, only for fun, mechanical part breaks down easily) The other one is magnetic glass cleaner, useless. Traditional way is using plenty of cleaning solution and rinse, then dried with cloth.
最後修改時間: 2020-03-29 08:43:04 -
- #9 [phil.ng], 20-03-29 08:25
手動丶慢好多丶要有臂力丶手力
手動轉速吾夠快丶難轉灣
紅色丶手動丶大型五金買過。
一條長snake 根本上用吾到丶得個様,因扭力傳吾到去個頭
淘寶什麼都有
最後修改時間: 2020-03-29 08:35:56 - #8 [phil.ng], 20-03-29 08:20
Power snake
- #7 [phil.ng], 20-03-29 06:37#1的好用丶外國我常用丶因可入完數寸丶再入數寸丶受到壓力
#4的成條長野丶好難入丶只合直喉 - #6 [alexanderkoo], 20-03-29 06:13Don't buy, basically useless. Can only go through one bend, not anything magical.
- #5 [tytony], 20-03-29 01:37不是這1隻,是我上邊照片那一款,sellery 通渠神器,彈弓可以收埋的,youtube 有,但我唔識copylink
- #4 [亨利二世], 20-03-29 01:08呢啲? 好多家品店都有.
- #3 [tytony], 20-03-29 00:58不是打氣的,是好似彈弓可以攪的
- #2 [new68u], 20-03-28 23:41如果係加壓打氣入喉既, 日本城布類似的, 有兩個size.
- #1 [tytony], 20-03-28 23:31搵咗好多度都冇!
Toilet 用丶淘寶有手動的
