- #11 [0925], 22-11-13 07:09https://youtu.be/UqNTt9Fz0iU
- #10 [cornercube], 22-10-07 06:45google
drill bit shank types
tinyurl.com/56r3uxn6 - #9 [alexanderkoo], 22-10-06 07:58Hammering drill bit is of two types, one rectangular (4 slots) the other round. Won't fit if you buy the wrong type. Got both sets.
The ones with hexagonal shanks are useful for drilling metal/wood, fitted with impact driver. -
- #8 [CS168], 22-10-05 22:53
油壓鑽咀係開坑,特别巧力强勁! - #7 [sonyboyhk], 22-10-05 22:47#6 parker75 兄
可唔可以分享一下 ?
thanks - #6 [parker75], 22-10-05 11:46石屎鑽,有分油壓鑽用,同一般平鑽用。
頭一樣,尾唔同的。
買時小心。 - #5 [我是一個人], 22-10-05 11:42用得最多DeWalt 果套
- #4 [sonyboyhk], 22-10-04 23:54thanks all brother
- #3 [alexanderkoo], 22-10-04 08:19Simply go to metal store and you get the answer. There is special drill bit for dual purpose, metal and concrete, good for drilling rivet with concrete underneath. Haven't tried out yet. Special drill bit for glass, ring saw type for larger opening.
- #2 [0925], 22-10-04 00:40
- #1 [sonyboyhk], 22-10-04 00:21
日常遇見的鑽頭(批) , 請問如何可以分辨屬於那一類 :
1. 鑽金屬
2. 鑽木
3. 鑽石屎
謝謝指導 - 返回 ...
