- #25 [mcdull], 19-02-27 14:34
- #24 [S.Chan], 19-02-27 14:26請問油壓鑽加轉換頭後適合鑽乜用。Tks.
- #23 [mcdull], 19-02-27 10:04鑽木要平鑽 (即唔係用四坑頭) 用轉換器都唔會準.
所以冇乜人用油壓鑽鑽木, 除非你係用來當破柴咁鑽. -
- #22 [alexanderkoo], 19-02-27 09:46Very clumsy to use hammering drill to drill wood, different drill bits. Would need an adapter chuck. very long.
Some hammering drills are having chiselling function, very useful for large through wall hole,70mm for refrigerant pipes. - #21 [cornercube], 19-02-27 09:43油壓鑽 鑽咀 虛位大..
- #20 [DeepSea^^], 19-02-27 09:37鑽木的話,用電鈚都夠力。
- #19 [Bantex], 19-02-27 09:16咁。如果鑽木的話。
係咪都係油壓鑽不二選?
謝謝 - #18 [alexanderkoo], 19-02-26 17:18Hammering drill, hammering action via spring. Percussion Drill driver, pulsating rotary torque, different principle. Impact driver, for fixing and loosening nuts. Got all of them.
最後修改時間: 2019-02-26 17:21:23 - #17 [Ef9], 19-02-26 14:00以前D 油壓鑽 貴好多,而家平到三幾佰已有,一定好過普通鑽。
- #16 [shektau6], 19-02-26 13:49Guess I am keeping my hydraulic drill even though it's used only few times.
- #15 [WeWa], 19-02-26 11:38
#9 #10 #12 同意!
「衝擊鑽鑽石屎,鑽到把鑽出煙都未必入到2吋」
#4 條片解釋好清楚。
最後修改時間: 2019-02-26 11:46:05 - #14 [Ff4300], 19-02-26 11:28
- #13 [mcdull], 19-02-26 11:06#7 宜家果把充電都係油壓來.... 6mm 夠用.
- #12 [bliss33], 19-02-26 01:34唔塞野貪輕便買過衝擊鑽鑽石屎,鑽到虎口,膊頭刀痛呀^-^
- #11 [CS168], 19-02-26 00:40
用過油壓鑽乃就知石屎牆都係豆腐!!
衝擊鑽??鑽到天光了!!一身汗呀!! - #10 [Cherwowo], 19-02-26 00:22一定係買油壓鑽好
衝擊鑽鑽石屎,鑽到把鑽出煙都未必入到2吋 - #9 [CS168], 19-02-26 00:10
石屎牆,當然油壓鑽喇,
好多情況係就吾到力,
油壓5-6秒直入又快又準。 - #8 [伊雲士], 19-02-25 23:56呢隻算大陸好牌子 人仔360!
- #7 [Richardw], 19-02-25 23:54多年前在宜家買了一把,幾好用。應該不是油壓,但家用的,細細把,收藏容易,轉下窿仔已足夠了!
- #6 [呀金], 19-02-25 23:52
- 下一頁 (4 of 5)
叫多個用途, 例如唔講究既工程, 要木門開個孔, 咪可以用佢囉.
但預左開出來唔平整.
