- #45 [RickMax], 19-05-15 22:45係就順便換埋油
- #44 [patrick88], 19-05-15 22:40把舊油壓鑽買左廿幾年, 想換英式插頭, 但發覺電線膠皮老化, 要換埋電線.
- #43 [patrick88], 19-05-13 21:26加相
- #42 [patrick88], 19-05-13 21:14有把油壓鑽收埋左好多年冇用, 插電後仍然運作正常
原來係 MIJ, 又小巧, 現在揾吾返(濕電計)
最後修改時間: 2019-05-13 21:25:50 - #41 [0925], 19-03-05 01:17
- #40 [cornercube], 19-03-04 19:44
- #39 [cornercube], 19-03-04 18:09佢咁細把 470火 叫電錘
https://www.makita.com.hk/zh-hant/products/detail/570/
我理解咁分,
utube:
http://tinyurl.com/y4jqglsv
hammer drill= 電錘?
rotary hammer = 油壓鑽?
最後修改時間: 2019-03-04 18:28:09 - #38 [眉仔], 19-03-04 17:48
- #37 [cornercube], 19-03-04 17:31up下
家用, 1年 或 鑽 3幾個,
細細把600火都已經OK
好多大窿要鑽 或 深窿要鑽,
800火附近.
大火d, 好力d, 大把d, 重d & 貴d. - #36 [眉仔], 19-03-04 16:16請教一下, 依家用衝擊鑽鑽主力牆, 根本鑽唔入, 想買一把紅M油壓鑽. 上網見有好多型號, 請問應該買甚麼型號較好? 謝謝
- #35 [alexanderkoo], 19-03-01 08:29I am using this one(plus an old 220V Metabo drill, MIG, very robust) Quite handy and for village house internal partition(only sand brick), no problem at all. Concrete 5/16" usually.(for fixation and eye bolt for lifting, 3/8" for heavy loading such as split type at external wall but not recommended due to illegal structure)
https://www.amazon.co.uk/Ryobi-R18SDS-0-Cordless-Rotary-Hammer/dp/B00VEU9JZC/ref=sr_1_1?ie=UTF8&qid=1551399750&sr=8-1&keywords=Ryobi+hammer+drill
Bare tool only, can have another drill set for the compatible battery. Can't ship lithium battery alone.
最後修改時間: 2019-03-01 08:30:12 - #34 [alexanderkoo], 19-02-28 06:08If you drill granite, you need a very powerful one. For home application, it's only for 3/8" or 5/16" max. Check dia. of the anchorage bolt for proper drill bit. For larger size(say for water pipe),you can drill small hole first and then change to larger drill bit. Slower but can still accomplish the work.
- #33 [gary3886wong], 19-02-28 01:00建議初學用衝擊鑽,學下手感,力度,控制鑚速同扭力等,
學鑽唔同物料分別,石屎,磚,不鏽鋼,鋁角,木材,除拉釘等
鑽返兩三年,有經驗到時轉用油壓
而且油鑽結構虛位比衝擊鑽大,新手難掌握
最後修改時間: 2019-02-28 01:01:09 - #32 [S.Chan], 19-02-28 00:26呢碌嘢仲未用過, 遲些可能要用.
- #31 [呀金], 19-02-28 00:17
- #30 [0925], 19-02-27 20:53
最後修改時間: 2019-02-27 20:54:11 - #29 [S.Chan], 19-02-27 14:54試過用手搖吓佢都郁郁吓咁.
- #28 [mcdull], 19-02-27 14:40其實你拎上手一開機就知, 唔用converter, 插知四坑都"發發"下...
如果你有長鑽頭, 上左去一開機, 劃個大圓圈添. - #27 [S.Chan], 19-02-27 14:36兩位師兄,tks.
- #26 [DeepSea^^], 19-02-27 14:34鑽鐵閘、角鐵、金屬。
- 下一頁 (3 of 5)
