- #25682 [0925], 24-04-02 23:01
- #25681 [0925], 24-04-02 08:15
- #25680 [0925], 24-04-02 00:00https://forums.timezone.com/index.php?t=tree&goto=7768485&rid=0#msg_7768485
最後修改時間: 2024-04-02 00:01:01 -
- #25679 [0925], 24-04-01 23:57https://forums.timezone.com/index.php?t=tree&goto=7768454&rid=0#msg_7768454
The case, in stainless steel, satin-brushed and polished, measures 39mm x 36mm x 15.6mm. It has a sapphire crystal reflective prism, a partial display back, and it is water resistant to 50 meters.
Movement is the Swiss automatic Soprod caliber NEWTON P092 with 23 jewels, 28,800 vph and a power reserve of 44 hours. Jumping hour disc developed in-house with 9 mechanical components and 6 It features Cotes de Genève, sandblasted, circular-grained and a skeletonized rotor. Rhodium-plated finishes.
最後修改時間: 2024-04-01 23:59:20 - #25678 [0925], 24-04-01 23:51https://forums.timezone.com/index.php?t=tree&goto=7768453&rid=0#msg_7768453
最後修改時間: 2024-04-01 23:52:49 - #25677 [0925], 24-03-31 23:19
- #25676 [0925], 24-03-31 23:10https://forums.timezone.com/index.php?t=tree&goto=7768433&rid=0#msg_7768433
最後修改時間: 2024-03-31 23:10:31 - #25675 [0925], 24-03-30 23:44https://wristreview.com/introducing-the-new-instruments-de-vitesse-watches-from-angelus/
最後修改時間: 2024-03-30 23:44:37 - #25674 [0925], 24-03-30 23:40
- #25673 [0925], 24-03-30 16:07https://forums.timezone.com/index.php?t=tree&goto=7768337&rid=0#msg_7768337
最後修改時間: 2024-03-30 16:08:00 - #25672 [0925], 24-03-30 16:05https://forums.timezone.com/index.php?t=tree&goto=7768327&rid=0#msg_7768327
最後修改時間: 2024-03-30 16:05:44 - #25671 [0925], 24-03-30 16:04https://forums.timezone.com/index.php?t=tree&goto=7768326&rid=0#msg_7768326
最後修改時間: 2024-03-30 16:04:42 - #25670 [0925], 24-03-30 16:02https://forums.timezone.com/index.php?t=tree&goto=7768325&rid=0#msg_7768325
最後修改時間: 2024-03-30 16:02:53 - #25669 [0925], 24-03-30 15:59https://forums.timezone.com/index.php?t=tree&goto=7768294&rid=0#msg_7768294
最後修改時間: 2024-03-30 15:59:49 - #25668 [0925], 24-03-29 05:29
- #25667 [0925], 24-03-28 21:24https://forums.timezone.com/index.php?t=tree&goto=7768272&rid=0#msg_7768272
最後修改時間: 2024-03-28 21:24:58 - #25666 [0925], 24-03-28 21:20https://forums.timezone.com/index.php?t=tree&goto=7768270&rid=0#msg_7768270
最後修改時間: 2024-03-28 21:21:04 - #25665 [0925], 24-03-28 21:18https://forums.timezone.com/index.php?t=tree&goto=7768171&rid=0#msg_7768171
最後修改時間: 2024-03-28 21:19:22 - #25664 [一縷炊煙], 24-03-28 02:48新錶,幾百蚊貨色,擠埋多年,今日攞番出黎戴,仍行得走得,機械錶,預咗5準,但希望5好相差太多,5係填得海
- #25663 [0925], 24-03-27 22:15
https://www.aliexpress.com/item/1005006174301475.html?aff_fcid=8c83e4eab1bd420b90e3fcf2d7b47a1b-1711548857544-08102-_DCjh3wH&tt=CPS_NORMAL&aff_fsk=_DCjh3wH&aff_platform=shareComponent-detail&sk=_DCjh3wH&aff_trace_key=8c83e4eab1bd420b90e3fcf2d7b47a1b-1711548857544-08102-_DCjh3wH&terminal_id=8bc8797a042b49e189f92aa877a84f9c&afSmartRedirect=y
Shipping was fast, came to me in 9 days, packaging was very good, a branded watch box inside an other cardboard box. The watch itself is very beautiful, it is not to big, I measure a good 41mm across the dial. 13mm thick. Case is well made and finished. The sapphire glass is very thick also the glass in the back is thick (usually this is rather thin). The dial is very detailed and well finished and the hands perfectly aligned. The inner ring works very smooth. I read a review from someone who said it was difficult to position correct but I don't have any problem with it, I really can set it correctly. The miyota movement is a 12 seconds fast in 24 hours which is very acceptable, it could be better also could be worse. I think it's a modern version of the movement because it hacks and there is no problem whatsoever with hesitating seconds which was a known problem with earlier miyota's. There is however one negative item for me : berny should put more removeble links in the bracelet. - 下一頁 (6 of 1289)
最後修改時間: 2024-04-02 23:02:04
