- #47 [katfish], 22-11-23 12:54Thx ! But I will still need to take it to the shop (one I know for many years) for upgrade .. prefer not to (coz I don't know) upgrade myself.
- #46 [lym], 22-11-23 12:53吾成日影相,咁吾係好大需要姐。試下 optimize 下架機睇下接吾接受到先囉。
- #45 [hahayanyan], 22-11-23 12:51hey...no need to go to shop la
it cost too much time and cost at hk
it the right time and right device to inspire yourself for some basic DIY haha
all u need to do..
open up that PC..., take a look the power supply output
lets say..if it is only 250W to 300W output... goes for a low end i7
if it is a 350W...goes for a mid model
if it is 450W plus... goes for highest model
if the power supply do not have a label at all.............dont be too greedy ..goes for a low end i7 which demand 35W only
PT100
i know...but some PC may really only have 250W 70 % efficiency power supply... if he goes for 4770.... it can be quite a nightmare
haha
最後修改時間: 2022-11-23 12:54:42 -
- #44 [PT100], 22-11-23 12:50#42
買到i7-4770S or i7-4790S,TDP65W係下限,4790T雖然係35W,但做剪輯會太冇力! - #43 [katfish], 22-11-23 12:47Dunno ah .. so long ago hahaha.
may have to take the box to the shop and check and discuss and quote different upgrade options
最後修改時間: 2022-11-23 12:48:23 - #42 [hahayanyan], 22-11-23 12:45katfish
what is your power supply?
some i7 consume 85Watts
some at 60 watts
some at 35 watts
if your power supply is not strong...and u have a 85W i7..., u will get blue screen etc...
but for sure...rmb 300 to 400 additional spending... things will be better
最後修改時間: 2022-11-23 12:46:33 - #41 [PT100], 22-11-23 12:42#37
買部全新i3係快佐,第九代時經已係呢個情況,但至少要花3K!同300幾升級係兩種概念,個人消費取向問題!
講真電腦點先係夠用,要自己先知,個人腦慢或工作量低。。。部電腦快唔快都唔知啦!
最後修改時間: 2022-11-23 12:45:42 - #40 [katfish], 22-11-23 12:41我只係一兩個禮拜影一日相。執相都只係30/40張, 所以花七、八千買部新電腦,我就覺得唔值得。不過大家都見到咁啱有啲硬件(CPU, C drive SSD) 其實都已經開始到上限 (我個1T HDD 都差不多80%+ 滿),所以諗upgrade。當然各大大師兄如果覺得小修小寶都係嘥錢咁就一炮過⋯
Thx very much!!! - #39 [gchp], 22-11-23 12:35For someone like me...
Doing some upgrade to i7-4790K and 32G RAM with Geforce 1650S of course with SSD... i would say it's still strong and deliver
I do some photo/video editing too and still very tolerable to me..
Hope it helps. - #38 [hahayanyan], 22-11-23 12:29for some people..
they do not want to waste some hardware
based on that hardware ...
and dun be too aggressive if the power supply is marginal too
for a good 4th i7 at higher clock rate ..demand better power supply and it may cost rmb 400
for some low end 4th i7... it consumer half the power vs those high end model
no matter what..it will be better ...from the i3 become i7
dun be too aggressive , if u do not know much about your power supply , in this case..goes for a mid model...it cost u rmb 300 ish
if u have a good power supply...goes for the best 4th i7
最後修改時間: 2022-11-23 12:41:49 - #37 [skyliner], 22-11-23 12:04你而家買部i3都快過4代i7,
咪漇錢啦。 - #36 [PT100], 22-11-23 11:41#35
Ram佢足夠,4代i7二手仲要接近400元呀!不過與i3當然係兩回事,要求唔太高係可以考慮! - #35 [hahayanyan], 22-11-22 13:31走去淘寶買返一個第四代嘅i7 可能百幾二百蚊
畀個機會佢發揮下囉... - #34 [kkc3], 22-11-22 13:30ssd就爆, cpu,display cad入門级,大把升级空間,慢慢在u tube做功課再望下有幾多budget後自己决定~
- #33 [alexanderkoo], 22-11-22 09:32Check you MB details for RAM/CPU support. Otherwise, everything is a futile. Just purchased 16G ram/512SSD for my labtop, two different things, due to Black Friday sales.(saved only a bit)
最後修改時間: 2022-11-22 09:33:07 - #32 [Philippe], 22-11-21 15:45執相i5都慢啦,i3唔敢想像.16G ram, 512G SSD只係勉強夠,要睇吓點執,相機像素越來越高,要疊相有時都會唔夠要分幾次做.
- #31 [G1], 22-11-21 14:16Intel 4 代,都6-7年機,諗換機實際啲
- #30 [hahayanyan], 22-11-21 13:59感覺有啲慢, 即係你嘅期望 不需要很快, 現在還能勉強接受?
如果係咁.. Just change the cpu and add ram
如果你嘅期望係需要很快... 買第二部
如果真係有啲DD 慢... 你懂得怎樣優化您的電腦可以令佢快一點 based on the existing hardware? Always nice to optimize it
最後修改時間: 2022-11-21 14:00:48 - #29 [lym], 22-11-21 13:37咁試下用第隻 software 比較下。你 i3 粒CPU 得 2 cores/4 threads. image/video editing 可能差D.
- #28 [katfish], 22-11-21 13:28Studio NX. 考慮換 Lightroom / Luminar AI / NEO / Capture One
- 下一頁 (4 of 6)
