- #87 [hahayanyan], 22-11-26 12:00
- #86 [gchp], 22-11-26 11:55Yes... latest intel chipset is Z790 which supports 12th and 13rd gen Intel processors
But i always go for a wait and see approach for latest available hardware and software.... bug is a concert as always as based on experience ... 切勿跟車太貼
Like Windows11... i would never go for it until after Win10 enters into EOL. - #85 [cornercube], 22-11-26 08:35E+砌電腦 ,
try
Z690或Z790 chipset d 底板....
https://pcpartpicker.com/products/motherboard/#s=40&c=162&sort=-formfactor&page=1 -
- #84 [skyliner], 22-11-26 08:04講左唔好買2 physical core。平都係咁話
- #83 [new68u], 22-11-26 07:33平
- #82 [alexanderkoo], 22-11-26 06:41Asus vivobook 15 i5, 8/256 only about HK2500, shipping HK 190. Amazon.uk. Didn't buy since CPU at least two generations lagging. Acer aspire 5 is better wrt metal construction and other spec. Still no PCIe generation 4 for SSD. Similar spec. as the one I have been using but generation 8 CPU. Would rather go for i7 and 512 SSD. Ram is easily upgraded, $280 for Teamgroup 16 G. $250 for crucial 512G M2 nvme SSD.
Kid bought HP gaming laptop on Taobao at $ 9500 few years ago. Would have warned him if I knew about this. Honesty and warranty problems. Repair can be $1000-2000. Sending back for repair? Never, you may not have the gadget anymore.
最後修改時間: 2022-11-26 06:46:49 - #81 [BenYC], 22-11-25 15:00https://www.userbenchmark.com/Software
I am clueless in computers myself. I used the above site to can get some idea. - #80 [katfish], 22-11-25 12:36#4 Thx.
Re " .... its better to just upgrade the computer instead of throwing good money into old ones" . you gotta have the know-how to tell which is which !
LOL. - #79 [katfish], 22-11-25 12:31Thx Koo-Hing. That all-in-one is definitely one way to do it .
- #78 [lym], 22-11-25 11:43幾抵喎,買返來自己 upgrade RAM。
- #77 [BenYC], 22-11-25 11:39#74
This is true. This is why better get a good current GPU that you will use if you want to get a new computer.
Afterall, its better to just upgrade the computer instead of throwing good money into old ones. Spare computer can always be used to connect to TV and watch youtube/netflixand do some home entertainment stuff that does not need much processing power. - #76 [new68u], 22-11-25 11:18$31xx
- #75 [hahayanyan], 22-11-25 10:28【淘宝】https://m.tb.cn/h.U7CQr47?tk=AZsVd2YSRtj CZ0001 「I7 4790 4770 4790K 4790S 4770k 4770s 4765T 4785T 1150针CPU」
点击链接直接打开 或者 淘宝搜索直接打开 - #74 [gchp], 22-11-25 09:19#70
Not every Photo editing software supports every graphic card... u better do some home work 1st...
https://helpx.adobe.com/hk_en/lightroom-classic/kb/lightroom-gpu-faq.html - #73 [alexanderkoo], 22-11-25 06:01Taobao, Beelink GTR 5(6 is newest), very popular. As found on Amazon at higher price, being raved, see feedback.
No longer DIY in building pc, no new knowledge acquired. Only updated spec. for individual parts. Just replaced a 4 yo laptop MB, would upgrade from 8/256 to 16/512. Parts from Amazon. CPU, soldered to MB, almost non upgradable.
Must have warranty cards for components, not used/bulk pack. Overall one year warranty.
最後修改時間: 2022-11-25 06:06:10 - #72 [katfish], 22-11-25 01:16THX!!!
- #71 [hahayanyan], 22-11-25 00:11key word "how to assign graphic card specific application"
one of the way
From Start Icon, type "Graphics Settings". Click the results from System Settings.
Click Desktop App.
Click your application. ...
Once identified, click Options.
Set the application to your preferred GPU.
Click save.
the other way
https://pureinfotech.com/set-gpu-app-windows-10/
最後修改時間: 2022-11-25 00:12:01 - #70 [katfish], 22-11-24 23:51Yes. Also " ...執相程式硬行graphics card(唔好比電腦自動選)"
- #69 [hahayanyan], 22-11-24 22:56Katfish
你嘅意思係你想嘗試diy? 但係唔識得搵適當嘅東西? - #68 [katfish], 22-11-24 22:36唔係好熟呢啲技術嘢
請問點樣search呢個題目? - 下一頁 (2 of 6)
am still using W7
... Am so outdated
Almost all of our engineers etc.. Those notebook and workstation
. Brought from overseas authorized refurbished dealer... With global warranty, and at hk, warranty was quite an straightforward process, for so many yrs, we had 2 warranty claims, mostly HP and some Dell (sometime Dell have super super cheap refurbished units, otherwise we do prefer HP)
They are different grade of refurbished unit too
We are cheap.... Haha save quite a bit
For upper end of Consummer grade PC /notebook, seem oversea is also cheaper for new ... Goes for hp or Dell, for the benefit for global warranty
Have fun..
If anyone have a reason for using workstation grade, take a look those USA authorized dealer for hp and dell
Those are no good for gaming and weight higher..
For hiend gaming notebook, oversea dealer also cheaper..
最後修改時間: 2022-11-26 12:16:48
