- #1 [katfish], 22-11-21 01:36
- #2 [blackspin], 22-11-21 01:48IMHO, upgrading the CPU and as much as RAM your motherboard can support
- #3 [呀金], 22-11-21 02:0116GB RAM 理論上足夠,SSD 如果唔係放到好滿(data主要放入HDD),亦不會是bottleneck。
我估CPU同display card影響比較大。
最後修改時間: 2022-11-21 02:02:05 -
- #4 [ttleung@], 22-11-21 02:05開個task manager 咪知邊個係 bottleneck 囉
- #5 [katfish], 22-11-21 02:22原來 256Gb SSD C: drive (210G available) 只有大概20G free。
- #6 [呀金], 22-11-21 02:28如果可以搬走某些不常用data去HDD,free番足夠SSD空間,就可以試到是否有幫助。
- #7 [blackspin], 22-11-21 03:17#5
For photo editing, the software always create TEMP file for processing, if your SSD does not have ample space, it will impact the overall performance........ Frankly 16GB EAM is really not an optimal configure for your application..... - #8 [radhk], 22-11-21 03:43upgrade cpu.
ram 16G一般都夠用.
執相個program放SSD. 或者隻HDD換埋SSD. 相save埋0係SSD. (當然安全計要做定backup, cloud或者用返隻HDD). - #9 [呀金], 22-11-21 04:17如果係我,會先試不花錢的方法,將SSD內不常用/唔等使的資料,搬去HDD,令SSD有足夠空間運作,唔得先考慮用錢的方法。
- #10 [cornercube], 22-11-21 07:05or google
computer bottleneck calculator
https://tinyurl.com/32rdfc5b
https://pc-builds.com/bottleneck-calculator/result/1dB0YB/1/general-tasks/1920x1080/ - #11 [MinnaNoTabo], 22-11-21 07:29如果你真係要換零件唔換機,
唯有就係換Display card - #12 [skyliner], 22-11-21 08:314代 dual core i3上網都慢到蟻躝,仲話執相。
買過部新嘅。 - #13 [olddude], 22-11-21 10:10i5執相都好勉強
- #14 [olddude], 22-11-21 10:12#11 行緊i3 display card用到RX都無乜幫助
- #15 [411], 22-11-21 10:35執相片換部MACBOOK AIR M1 8G.....
最後修改時間: 2022-11-21 10:35:54 - #16 [ich], 22-11-21 10:40換過部新電腦,有i7 12代,32G RAM, M.2 harddisk,獨顯.一定會快過之前好多.
- #17 [ck2007], 22-11-21 10:4913代I5 快過12代I7; 接近12代I9.
執相用有I5內GPU已經夠, VIDEO EDITING 只係RENDING 用獨顯加速。
最後修改時間: 2022-11-21 10:54:55 - #18 [MinnaNoTabo], 22-11-21 11:00用 M1 版 iPad Air可能仲有效率
- #19 [一號2世], 22-11-21 11:01Your C drive SSD should be SATA type, there is no way to boost the speed.
You need a PC having PCIe 3 slot and install a NVME SSD for the Windows system.
DDR3 ram is also a bottleneck even you have 16G ram, new system have DDR4 ram slot must be better. - #20 [Kenny], 22-11-21 11:02答案其實只有一個。
問題係有冇人見過有YouTubers 用PC執相或片?
樓主要學習用Apple啦。 - 下一頁 (1 of 6)
現有電腦配置:
CPU - i3-4150 2-core , 4 processor @3.5 GHz
16G RAM
Display Card: GT1030
C Drive (Boot) SSD - 512G
D Drive Regular HDD - 1T
Thx!
