- #271 [Mercury2015], 20-02-17 10:02
- #270 [alexanderkoo], 20-02-17 09:55#267 Don't think the pandemic will end by then. So, better hurry up, already a bit late to respond now. In the meantime, use disposable mask but having increasing difficulty to source. Don't imagine that the supply will return to normal very soon.
340hr Life. Don't think test certificate is available, simply reply on technology and design, assuming cleaner air and accumulation of particles.
最後修改時間: 2020-02-17 09:57:39 - #269 [呀金], 20-02-16 17:42其實不織布功能係靜電吸引病毒痴住...面積有飽和度....所以不能長用
所以不應該水洗或蒸。 -
- #268 [Mercury2015], 20-02-16 17:36>> 多放廚房纸可能難呼吸,我試過在外科口罩向面那一層放多一張面紙,呼吸頓時困難好多
我本來也想這樣, 比較方便不用自制整個口罩, 但看來是行不通, 重話要用兩層廚房纸, 再加外科口罩一定會呼吸困難了.
最後修改時間: 2020-02-16 17:39:38 - #267 [Mercury2015], 20-02-16 17:28>> Cambridge mask can be reused after washing with soap and hot water. 360 hrs.life and 3-6 months..
就算宜家落訂都要 Mid April 才可以出貨呢. - #266 [老吾老], 20-02-16 17:20.
- #265 [呀金], 20-02-16 16:08多放廚房纸可能難呼吸,我試過在外科口罩向面那一層放多一張面紙,呼吸頓時困難好多。
- #264 [winning7], 20-02-16 16:04可諗下自制多幾個口罩(可揀防水料做面), 中間放廚房纸, 放多兩三張都得
最後修改時間: 2020-02-16 16:06:02 - #263 [alexanderkoo], 20-02-15 20:36Cambridge mask can be reused after washing with soap and hot water. 360 hrs.life and 3-6 months. Posted on other thread. Similar to the one being developed by HKPU with layer of silver. Already in market!
- #262 [呀金], 20-02-15 17:19
- #261 [呀金], 20-02-15 17:14
- #260 [matrixneo], 20-02-15 17:09已經冇乜貨
要四五日一個口罩
大家其實用咩方法去清潔
交流一下
最後一句
林鄭死全家
最後修改時間: 2020-02-15 17:10:21 - #259 [alexanderkoo], 20-02-15 10:52Already thought about this few weeks ago. In the ancient days, people simply used handkerchief. Of course, leaves much to be desired.
- #258 [Mercury2015], 20-02-15 10:46#257
機構包括香港大學深圳醫院,香港消費者委員會,香港應用科技研究院,香港科技園公司和香港城市大學建築學及土木工程學系,可信性應該是很高,我也買了幾卷廚房萬用紙準備自制口罩呢.
只不過報導中簡單提及提醒市民切勿嘗試用任何方法,包括....去清洗或消毒口罩, 因為會影響過濾效能,使口罩失去防護作用,這個是很多人關心的問題, 基於仍然有一點效用好過完全沒有的想法, 自然就想知道多一些細節,例如實際效率下降多小?
另外小弟看過一份之前 R33 網友 Post 過 來自台灣機構的拋棄式防塵口罩滅菌再使用之可行性探討報告, 內容有詳細列出實驗設備,實驗方法,如何進行微粒穿透率測試以及各種方法消毒後捕集效率下降多小的實際數值.
最後修改時間: 2020-02-15 10:52:48 - #257 [ich], 20-02-15 09:29#254,#256
同樣問題可以用在每一個口罩上.Figures and data大部份建基於信任上面.Air filter efficiency 係好簡單基本test, droplets 瑩光顯示亦唔難.我個人覺得 呢次combined force effort 可信性高.我都會嘗試做一個 - #256 [Mercury2015], 20-02-15 08:54沒有透露詳情,例如實驗設備,實驗方法,如何進行微粒穿透率測試?
還有提及自行清洗消毒外科口罩,例如用60度水温的肥皂水清洗外科口罩等等,會影響過濾效能,使口罩失去防護作用,但未有提及具體數值效率下降多小?
最後修改時間: 2020-02-15 08:57:18 - #255 [winning7], 20-02-15 08:46港大深圳醫學院聯同消費者委員會、城大建築學及土木工程學系、香港應用科技研究院及香港科技園成立工作小組,研究自製口罩。經實驗證明,自製口罩可達到外科口罩 9 成以上的過濾效果。>>
可能有d料到, 等下其他學者分析下
FDA food grade compliance
https://www.fda.gov/FOOD
最後修改時間: 2020-02-15 08:51:46 - #254 [呀金], 20-02-15 04:23消委會曾經測試厨房紙,但無提及任何過濾要求,主要是吸水速度/吸水量/拉力/細菌量等等。
暫時揾唔到過濾規格... - #253 [winning7], 20-02-15 04:16廚房紙要達到處理食物衛生規格參考標準............um
- #252 [happy123], 20-02-15 03:45
- 下一頁 (1 of 14)
技術資料...
