- #54 [S.Chan], 24-05-18 16:57celestion hing, thanks,
- #53 [celestion], 24-05-18 14:54S.Chan #51
血壓13x-140左右, no problem. - #52 [micromegamah], 24-05-18 13:57
- #51 [S.Chan], 24-05-18 12:38#47 celestion 兄
E+血壓13x-140左右.無運動,年紀不小了. - #50 [大白兔], 24-05-18 12:33應該有dd 幫助
- #49 [Mercury2015], 24-05-18 11:06咁會唔會可能有其他因素影響咗你的血壓. 例如你有冇生活方式的改變, 運動做多咗, 飲食習慣改變, 低糖, 低鹽, 低膽固醇, 素食.
- #48 [0925], 24-05-18 10:59
- #47 [celestion], 24-05-18 10:57S.Chan #40
食粒半都好高. - #46 [alexanderkoo], 24-05-18 08:39Not exactly inflammation, kind of disorder in controlling blood pressure leading to hypotension.An excerpt.
“Cardiovascular autonomic dysfunction (CVAD) is a malfunction of the cardiovascular system caused by deranged autonomic control of circulatory homeostasis. CVAD is an important component of post-COVID-19 syndrome, also termed long COVID, and might affect on”
最後修改時間: 2024-05-18 08:40:10 - #45 [alexanderkoo], 24-05-18 07:50That's weird. Inflammation would cause constriction in blood vessel, hence higher blood pressure. Low oxygen level would cause heart racing, understandable.
- #44 [S.Chan], 24-05-18 00:32剛google如附圖但我無咁嚴重,只微燒兩天,輕咳就成個月有多.
- #43 [S.Chan], 24-05-18 00:27只係短短果三幾日發覺,病情輕微並無告知醫生.
- #42 [Mercury2015], 24-05-18 00:01我都中過新型冠狀病毒,之後唔覺自己血壓低咗,我諗呢個世界上有很多人中過新型冠狀病毒,好像很少聽過有報導說中完新冠病毒之後會降低血壓, 咁你覆診的時候有冇同醫生講這種情況? 之後醫生有冇解釋為什麼會這樣呢?
- #41 [micromegamah], 24-05-17 22:28咁神奇
- #40 [S.Chan], 24-05-17 22:07我中新冠時血壓都比平時低幾多吓,平時 140 可以去到 110.
之前覺得血壓低咗小小,政府覆診時問可否減藥,佢叫我自己試吓。每日粒半未試因近排唔太低。 - #39 [Drhandguns], 24-05-17 20:43第一句忠告就係, 睇醫生+等醫生配藥。
好多人問點解要長期食血壓丸, 呢度咁多玩hi-fi人, 應該知點解要裝fuse, 就算你平時靜止嘅時候血壓好低, 有咩刺激都會令到你血壓飆升, 呢度大部分人都一把年紀啲血管就等於一部古董hi-fi裏面啲電容同線材, 如果一有power surge, 好容易會燒fuse, 食血壓藥就係防止突如其來嘅power surge。
你有好多人問血壓丸可唔可以停, 答案係可以, 不過要醫生斷定你嘅電流夠低, 有power surge嘅機會好微, 咁就會叫你減藥甚至停藥。 - #38 [alexanderkoo], 24-05-17 19:42慢性的要,因為找不到原因,這正是對抗療法的大方向,消滅徵状,不是醫好
最後修改時間: 2024-05-17 19:43:25 - #37 [八達通], 24-05-17 18:29血壓藥又未必要食ㄧ世
之前中左新冠,自已停左藥兩星期
停左藥血壓都正常,食返兩日血壓仲降得好低仲頭暈就無再食
不過覆診醫生話:你藥都停埋,甘你吾使再返黎覆診哪 - #36 [alexanderkoo], 24-05-17 15:53太太在公立醫院(公務員family clinic) 取药,太多了,有時要求不要開,還是比較贵的cozaar. 因她度完血压才調較份量,食了之前列出的三種補品,可恨是沒有止痛的celebrex,祇有 Panadol,還是血糖較難控制,為食,胆固醇可以不理,祇要TGR 低及HDL 高, 三高可以全中,互相牵引,基本是高醣及碳水化合物缘故,很多網友還未醒覺
我没有薄,無需定期複診,很少食西药, COVID 至今,無看醫生,打预防针,牙科及眼科預约除外
一死就死,不用食药,或疑神疑鬼,才是最快樂
最後修改時間: 2024-05-17 16:09:25 - #35 [Mercury2015], 24-05-17 12:29還有其他好處,公立醫院收費比較低適合一般市民,每三個月或半年見一次醫生,如果覺得身體有什麼不舒服可以和醫生講讓醫生持續跟進你的身體狀況.
- 下一頁 (1 of 3)
