- #574 [hahayanyan], 20-09-22 19:10
- #573 [rover901], 20-09-22 08:51Both look very vintage :)
Nice! - #572 [hahayanyan], 20-09-21 12:47Pedals of today... Haha
One of them ...Dr. scientist , super fun pedel for getting strange non sense sound
The other one is a dumble clone from china by a maker called Noname
Good stuff -
- #571 [hahayanyan], 20-09-19 21:00yes
some bleaches work for that purpose as they are oxidizing agents
最後修改時間: 2020-09-19 21:00:54 - #570 [BenYC], 20-09-19 19:50#567
Did not know about using acid to bleach. Great tips. - #569 [BenYC], 20-09-19 19:40Wow. Nice pedals.
- #568 [rover901], 20-09-19 16:43阿女考試用pedal board
- #567 [hahayanyan], 20-09-19 16:26Fun thread
#558, if there is any future repair for such crack, if someone care or try to get rip of the darker color crack
since the crack has been exposed to the air for quite sometime , it get oxidized, first we need to DE-oxidize it by using acid such as Oxalic Acid ,give it couple of mins or hour, many of the case, the darkened line will be less dark or apply those acid further until it match the color closer around it
then , next ...warm hide glue
最後修改時間: 2020-09-19 16:38:12 - #566 [BenYC], 20-09-19 09:19The noise is not resonance harmonics or buzz. The decay of the note has an unstable pitch. Say if I pick an e note, it will come out e and then pitch up to f gradually and fade out. This is not too abnormal but that pitch up is too loud and ear catching.
I think the problem is caused by the guitar body too stiff on all sides and some energy trapped inside.
I will play it more to see if this can improve. - #565 [r33er], 20-09-19 01:34"動動動 LLLL 動動動 LLLL 動動動 LLLL ......."
係咪咁既聲? - #564 [r33er], 20-09-19 00:56佢講既聲應該係 "動 L"咁既聲. 係 saddle 打磨得吾好
- #563 [prs], 20-09-18 21:31
- #562 [rover901], 20-09-18 19:51Oh......
New nut should be positive in sound , how come? - #561 [BenYC], 20-09-17 19:47Reporting back on changing a c40 yamaha classical guitar nuts and bridge to bone. After letting the strings settled, I noted the sustain is lengthened but with very uneven harmonics waving up and down. I prefer the original plastic nut and bridge. Probably my wrong and Wasted 2 hours... :(
最後修改時間: 2020-09-17 19:47:42 - #560 [Forestpig], 20-09-14 01:28Wow, Great repair job, Ben hing
- #559 [rover901], 20-09-13 21:13Nice work :)
- #558 [BenYC], 20-09-13 20:02Hi Rover. I do like handicraft.
Martin glue dried enough to wipe clean. Yet, the crack is still visible if look closely. I will leave it like this as the split is contained. No touch up as not sure about guitar varnish. - #557 [rover901], 20-09-13 18:58想當年
- #556 [rover901], 20-09-13 18:53好有心機喎,Ben 兄 :)
我支低階mini strat 當初換左骨nut都有好明顯的改善 - #555 [BenYC], 20-09-13 13:12Screw it... Since I heated up some hide glue to set nut. Will take the easy way to glue the crack. After all, just a small crack not thru and I am too lazy to set plate to clamp. Will clean the glue residue when dry
:) - 下一頁 (3 of 31)
fun pedal
