- #4 [alexanderkoo], 23-02-09 09:13
- #3 [alexanderkoo], 23-02-09 09:02Solder is of 138 or 183C, the latter is more common. Choice is dependent on temp which the board can withstand, not exactly the component operating temperature.(my CPU 40 C, only internet surfing) I think the heat sink compound would matter, ordinary one for transistor heat sink is bad, would simply melt. Hence, changed to Artic silver MX4 few days ago.(bought from amazon.de) Another casing opening.
However, I did find the component, capacitor of the notebook hard to desolder, using heat gun. Need more flux. In fact, two soldering irons working together would be OK, or prong type soldering iron which is overpriced.
https://item.taobao.com/item.htm?spm=a312a.7700824.w4002-2342127736.25.68b8698aL1S8Vp&id=554579186505
最後修改時間: 2023-02-09 09:09:37 - #2 [一縷炊煙], 23-02-09 05:39送終,就算免費都5洗旨意考慮
- #1 [呀金], 23-02-09 04:49
https://www.arctic.de/en/MX-4/ACTCP00007B
