- #441 [bambino], 21-04-30 20:56oh....you may check with manufacturer to see if you need to replace the heating element.
- #440 [hahayanyan], 21-04-30 20:46Haha it is really overstated at my machine
And yes.. Manual mode - #439 [bambino], 21-04-30 20:45yeah....heard that Behmor power setting is a bit overstated.
think you might be roasting on manual mode then
最後修改時間: 2021-04-30 20:45:40 -
- #438 [hahayanyan], 21-04-30 20:41Less bean.. 250 grams at 500 Gram setting and at full power...
From yrs of using that I do not think their setting is ok for 250 gram setting with 250 grams... Especially their program...
From understanding that particular machine... I then end up with half capacity... And total manual control
Haha yes.. Pass mid of FC.. Toward the end...
Only have to pay attention from the first pop sound... Haha.. The intensity... Of those pop sound.. And then guess...
最後修改時間: 2021-04-30 20:43:03 - #437 [bambino], 21-04-30 20:36heard that it's a bit difficult for Behmor to roast dark. to do that, do you have to roast less beans each time?
i see, you roast until it's close to end of FC....
最後修改時間: 2021-04-30 20:38:38 - #436 [hahayanyan], 21-04-30 20:33Yes haha... Take some luck to finish at that timing... At the end.. But not quite the end of first crack...
From first pop crack sound.. To more pop sound and guess how long does that bean to finish the first st crack cycle...
最後修改時間: 2021-04-30 20:35:29 - #435 [bambino], 21-04-30 20:16好靚, 用Behmor烘焙?
- #434 [hahayanyan], 21-04-30 19:51Haha not bad.. Come out as expected
初學者.... 可以平平哋買一些東西做手沖, 通常手沖都唔會太strong... 比較適合初初開始嘅人, 味道清新多一點變化多一點
#432 要知道嗰個 直徑... 喺淘寶買返嚟就可以啦
最後修改時間: 2021-04-30 19:53:44 - #433 [tonywong], 21-03-30 09:40
- #432 [Donhenley], 21-03-20 08:45Hello 唔知各位師兄仲有冇呢款 espresso 機咖啡濾網?
Thanks - #431 [hahayanyan], 21-02-11 01:08nothing wrong with capsules
but remember -- u drink coffee type of Beverage, not coffee
equally enjoyable
office had both...those flat were better, not sure ..was that because of more area for extraction to come out , or they alter the taste to make sure it taste better.. or this format was indeed better
but it make sense for those Flat round things are better , in term of physic ..
some of those capsules taste quite decent..because of additive - #430 [bambino], 21-02-08 20:17Ovator hing, Espresso does not seem to sell the type of capsules you posted in #428 now. I used to drink this type of capsules over 10 yrs ago in my office but no more Espresso since i left the company. Instead they sell the original & the new Vertuo capsules now, as shown below
The Vertuo capsule is named after VertuoLine machines which were originally developed for the American market, where people wanted to see capsules that would fill larger sizes of coffee cup beyond Nespresso’s Lungo size. For more information, please check the link below. However, if you look up Espresso HK website, they seem to sell the original capsules only. In term of the quality of coffee in different types of capsule, you'd better visit one of their shops. Their coffee machines can accept one type of capsules only. So, it's better decide on the capsule type first. Hope it helps.
https://whichnespresso.com/nespresso-originalline-vs-nespresso-vertuoline-whats-the-difference/
最後修改時間: 2021-02-08 20:18:42 - #429 [yukclee], 21-02-08 12:34Once you have tried freshly roasted beans and freshly grinded for a coffee, how would you be happy with capsules?
Just like once you stepped into the hifi world, you won't be satisfied with the mini combo units? - #428 [ovator], 21-02-07 12:36I am still trying to figure out if these Nesspresso plus capsule would taste better than the regular ones....
- #427 [ovator], 21-02-07 12:34Given the same Nesspresso capsule, is it possible for Creatista Plus to taste much better than a normal US$200 Nespresso machine ?
thanks - #426 [ovator], 21-02-07 11:46Has any brother here tried the Nespresso Pro capsures?
Is it much better than the original smaller ones?
Also, which machine can use nessspresso Pro capsule?
Many thanks
最後修改時間: 2021-02-07 11:50:55 - #425 [hahayanyan], 21-01-23 10:36When there is no mistake.. It is quite nice roast.. Haha
In the middle of first crack - #424 [ERIC711], 21-01-17 20:56wrong post
最後修改時間: 2021-01-17 20:57:50 - #423 [hahayanyan], 21-01-11 15:55Chaff... Thx you... Haha not skin
Yes it is chaff - #422 [bambino], 21-01-11 14:23i think most of the bean chaff comes off during the roasting process. it's left in the 尿壺 after i pour the beans. i also shake the beans in a perforated metal colander to cool them off as well as remove any chaff leftover. i have no idea of chaff weight though but think it's immaterial to worry about.
will have more practice using this 尿壺 before buying good quality beans :-)
最後修改時間: 2021-01-11 14:31:39 - 下一頁 (4 of 26)
