- #401 [bambino], 21-01-08 11:041st crack at 16 mins might be too long. i understand why you roast 250g at 500g setting. looks like Behmor is running under-powered.
- #400 [hahayanyan], 21-01-08 10:47temperature is fixed , there are programmed preset
but there is way to alter the timing and take a look the profile
but i do not use those preset , as i am using 500 gram setting for 250 grams
P1 and p3 is very useful , sometime p4
if it is 500 gram beans at 500 gram setting...the first crack for most of the bean is always at beyond 16 mins
for for 250 grams at 500 grams setting ...the first crack is always around 12 mins to 15 mins
so by having 250 gram beans at 500 grams setting ...it give a big enough for timing window to get so many outcome for a very light roast or super oily and dark roast...by P1 , P3 and P4
i guess hot air is better.. if there is freedom to tune the temperature.. too thermal gradient...etc.. i suppose those higher end roaster should have those features ... sensible upgrade wishes..haha
i do love to explore a different on set thermal gradient
The things is I hardly. Buy same bean more than 3kg, I do not think I can understand the thermal profile ofr that bean for some. Unique taste. Within 3kg..from 9 to 12 roasting session hahA
If someone who like particular bean for long term... And into this home roasting hobby... Worth to invest more than just those behmor... By having something with thermal profiling capability
最後修改時間: 2021-01-08 10:57:46 - #399 [bambino], 21-01-08 10:22can you adjust the setttings (temp, time,...etc) independent of the bean weight? (to achieve the same result)
there are other choices like Gene Cafe which i suspect would be similar to Behmor though. Bocaboca looks interesting and uses halogen lamp as heating source.
home roasters use different heat sources like hot air, fire & halogen lamp and they bring out slightly different tastes...
最後修改時間: 2021-01-08 10:25:38 -
- #398 [hahayanyan], 21-01-08 10:08Yes by the behmor, th e trick of using the behmor.. Is to using their 500gram setting for 225 grams
Haha
The darker one... I thought the crack was first... But actually when I pay attention to the crack sound.. It was already 2nd haha
Kind of quite even.. Kind of someone buy some not too cheap roasts beans and happy with that consistency lol
Sowmtime I check out other roaster...
But that behmor just so stable never have any issue for so many yrs.... Sometime I wonder.. If that broke.. What should I get next haha
最後修改時間: 2021-01-08 10:14:42 - #397 [bambino], 21-01-08 10:06very even roast, looks good!
is it by Behmor Plus? - #396 [hahayanyan], 21-01-08 09:53Kind of what I intended
Not bad roast... Haha
The 2nd roast is on. The way.. Seem I make a mistake.. Haha
最後修改時間: 2021-01-08 09:59:35 - #395 [hahayanyan], 21-01-05 11:44For home
I would say... All we need is an oscar
Unless we want to have thermal profiling
Such as we want this cup at 93 degree C but not 95Cor relatively lower or higher brewing temperature - #394 [ich], 21-01-04 16:33#393
Bought an Oscar in secondhand market may be 4 or 5 years ago. Serving my family faithfully non stop since. Prepared over 2000 cups and still running strong, never missed a beat. Steam froth is strong, really love this machine - #393 [hahayanyan], 21-01-04 16:24from all those yrs of many different machine...i believe anything bigger than oscar for home is just for sense of ownership but not really for coffee taste quality enhancement
just some of those better machine is kind of still affordable , then why not
haha - #392 [yukclee], 21-01-04 11:43#389 perfect idea...will copy it and use. I only use a Simonelli Oscar 2, which I find it very cost effective for an infrequent coffee drinker like me and it has a very good milk frother.
- #391 [hahayanyan], 21-01-03 13:58全自動機 with grinder too ? from bean to cup that kind of 全自動機?
- #390 [ckc87879484], 21-01-03 12:54請問全自動機有乜好選擇?可以人手打奶的
- #389 [hahayanyan], 21-01-03 12:09我用這個方法去dispense to portafilter
練習了個多星期, 效果進步了, every time 都好穩定好 平均
首先生粉放入去這個玻璃罌, 小型打蛋器打鬆啲粉
Then upside down as shown at photo.. A few shake... Just like we make cocktail... Haha
Coffee grind... Is then super even... Into the Portafilter basket haha
I find that many jug have almost prefect diameter for 58mm basket... Fit prefect forthe task
HahA - #388 [hahayanyan], 21-01-02 10:03祝大家新年進步日日飲好味咖啡
Haha so far.. 2021..ihave one good roast and one not too good roast..
Haha - #387 [yukclee], 21-01-02 09:55各位咖啡同好,祝大家2021身體健康,冲到好咖啡嘆!
- #386 [故人], 20-12-25 19:21hahayanyan兄,
謝謝詳細講解!
真的很有趣味。 - #385 [hahayanyan], 20-12-25 15:54只要係 粉嘅分佈 not 平均 inside the basket, 有啲地方有啲 眼睇唔到嘅比較大嘅間隙 令到啲水走去容易走嘅地方, 有啲地方就比較遲先至啲水滲到過去
這個情況,咖啡一定會比較苦澀嘅 or a taste of burnt.. Etc.. 因為有部分over extraction
從這些video你會見到有啲細孔比較遲先出coffee, 喺 中間一段時間 仲有一條頭髮絲嘅小水柱噴出, that is the channel for easier water path... we do not want to see
When review the coffee pad, 細心的觀察你會見到, 面嘅地方嘅深淺顏色不同
兩個地方出現咗問題, basket之前啲粉未準備得好, 例如有啲分組合成一小缺, 沒有被完全打鬆,靜電嘅原因令到有啲粉 組合成一小缺的
亦都係未凳好 粉, 已經心急咁 tamper 壓下去 甚至高低不水平 a little bit too much
以上總想多隻係 不留心 幾十秒內產生嘅錯誤
會做得好嘅只要留心一點點
Haha
最後修改時間: 2020-12-25 16:03:06 - #384 [故人], 20-12-25 15:32hahayanyan兄,
請問昨天espresso估計失準原因是什麼? - #383 [hahayanyan], 20-12-25 09:23
各位聖誕快樂
Better first shot today
Should be better if the grind is little bit finer
The. Morning first shot I aim for 1:3
The afternoon shot I aim for 1:2
Haha
最後修改時間: 2020-12-25 09:30:45 - #382 [bambino], 20-12-24 16:20佢吾只講理論, 仲做好多實驗. 可信性比較高.....
- 下一頁 (6 of 26)
