- #13 [alexanderkoo], 22-08-12 08:08
- #12 [111], 22-08-11 13:42露台趟門我用呢種,都ok 嘅
用1.5/kg集運運落來香港
窗你可以訂一兩隻窗試吓先,才全屋
78嘻P6pT2Hvx5Wp微 https://m.tb.cn/h.UagGNtR CZ0001 金刚网折叠纱门补差价 - #11 [111], 22-08-11 13:35窗我係呢處買,我用果種係窗花連蚊網一體,我見香港都有,叫什麼新款窗花連蚊網,但貴很多,用電批超易裝,你懶可在香港訂,但我估佢都係幫你大陸落order,magic 貼那種無用,以前住村屋用過,用過多種呢種最耐用最有效
17微9Oid2HvFcsN! https://m.tb.cn/h.fzSQ7GP CZ0001 新品高清防貓網金钢网防蚊纱网港式焊接窗花防盗窗铝合金纱窗自装 -
- #10 [alexanderkoo], 22-08-11 12:27Mosquito can spread contagious disease and cause nuisance to people especially during sleeping. Affecting ventilation is of lesser importance, in comparison.
Can have mosquito net for balcony sliding door, too, using magnetic strip to close. Measure top to bottom and width, off-the-shelf product.Can achieve 6 air changes when toilet/kitchen fans are switched on but bad to air conditioning.
最後修改時間: 2022-08-11 12:29:50 - #9 [浩男123], 22-08-11 12:22》空氣流通量即時減少 80%
有咁大影響?不過同俾蚊針,呢個就好過要關窗! - #8 [Dlbf], 22-08-11 12:12我見過朋友屋企係向外推出嘅窗門,去陶寶買咗後加磁石捲起蚊網,成個長方形貼上原有鋁窗框,睇落好似唔錯,
- #7 [tst1800], 22-08-11 10:47我住村屋, 落左蚊紗網, 空氣流通量即時減少 80%
- #6 [無奈], 22-08-11 09:39我都想裝...有無好介紹?
TKS
- #5 [alexanderkoo], 22-08-11 08:58Got a piece for balcony glass panel. The magnetic strip comes with longer length so you can cut more precisely during installation. So is the mesh. There is newer product with reinforced nylon in the middle to avoid collapse.
Can buy stainless steel wire mesh and custom made aluminium framework with hinges. But hard to work with, difficult to clean.
最後修改時間: 2022-08-11 08:58:26 - #4 [new68u], 22-08-11 08:10
- #3 [浩男123], 22-08-11 06:29淘寶?
- #2 [alexanderkoo], 22-08-11 06:15Yes, magnetic lift up one.
- #1 [浩男123], 22-08-11 05:54請問向外推的窗可以裝紗窗嗎?
https://www.amazon.com/Magnetic-Screen-Door-Retractable-Magnets/dp/B01ESSA9VO/ref=mp_s_a_1_2_sspa?crid=3SCX3ANDYPNLM&keywords=mosquito+net+for+door&qid=1660262829&sprefix=mosquito+net+for+door+%2Caps%2C348&sr=8-2-spons&psc=1&smid=A1WFZRQPDGQ55T
