- #1694 [hayden2810], 24-10-02 23:45
- #1693 [超音波], 24-10-02 22:49實有藉口話舊形號做吾到kkbox想你换機,你吾好整 ,不過我吾再買你個牌子?
- #1692 [上水小強], 24-10-02 20:05十分失望!U1唔得
最後修改時間: 2024-10-02 20:06:32 -
- #1691 [wklie], 24-10-02 15:35#1686:
KKBOX support for U2 / U2MINI / P1MINI / T3 / D3 is released. Please upgrade Firmware to 18.0, Lumin iOS app to 10.0, Lumin Android app to 7.0 .
All Lumin models receive Firmware 18 upgrade, but only the above models support KKBOX. For other models, you may use Roon to play KKBOX.
KKBOX lossless is only available in Taiwan, Hong Kong and Singapore.
Note: KKBOX display language (e.g. music categories and track and artist names) is fixed to be Chinese if user signs up in Taiwan or Hong Kong, regardless of Lumin app language setting. - #1690 [wklie], 24-10-02 15:32#1689:
Whole library shuffle is possible in Lumin app. Please try other apps.
Lumin app current playlist is limited to 2000 entries. - #1689 [lay133128], 24-10-02 01:15Is it possible to shuffle play the whole music library just like Roon does in the Lumin app ? If not possible, then is there an upper limit on the number of songs to be imported to the playlist ?
- #1688 [wklie], 24-09-17 14:34#1686:
U2 / U2MINI / P1MINI / T3 / D3: this month or next - #1687 [上水小強], 24-09-13 16:30之前問過!係唔可以用軟件更新!
- #1686 [salesleeon], 24-09-13 12:12想問下lumin串流播放器幾時有軟件更新可以直接登入kkbox
- #1685 [wklie], 24-08-20 17:30#1683:
所有現行 Lumin 型號 (M1 和 AMP amplifiers 除外) 均使用 2A Fast blow fuse。
All current Lumin models (except M1 and AMP amplifiers) use 2A fast blow fuse.
最後修改時間: 2024-08-20 17:31:52 - #1684 [wklie], 24-08-20 17:28#1682:
MTV9100D: BETA Internet firmware upgrade: date 2024-06-24
MTV9100D: Normal Internet firmware upgrade: date 2022-11-10
最後修改時間: 2024-08-20 17:30:24 - #1683 [LingCH], 24-08-18 20:52hello,
想請問一下,Lumin U2 機背電源插位置的Fuse,
是用幾多A 的?還有是 Slow blow 或是 Fast Blow 的嗎? 謝謝! - #1682 [kcsound], 24-08-16 13:24Dear wklie,
Good day.
It is our pleasure's to thanks you in person at the show.
Thanks very much for your prompt action and the continuous support at Pixel Magic.
The Lumin is working fine now. That's great.
May I ask whether any update will be apply to MagicTV as well. I am using the 9100D and there are a lot hiccup when using it. Always stutter and loss sound. There are no update avaible for quite awhile - since 2019.
Thanks & best regards. - #1681 [wklie], 24-08-12 15:55昨天有用戶反映新城電台不能播放。現在已經解決。請在 LUMIN app 內 update radio channels,或者關掉等幾秒再開啟LUMIN 機。
新城電台特別多出現問題的原因是 : 有別於正常的 internet radio station, 不知為何他們會經常不定時轉http link。如果有用戶發現這個問題再次發生,請e-mail給我們。 - #1680 [tom55], 24-08-12 10:40Lumin U1 mini crystal clock frequency ?
求教Lumin U1 mini 内4粒時鍾的頻率數值
最後修改時間: 2024-08-12 10:44:58 - #1679 [wklie], 24-08-11 09:37多謝師兄意見。同事選擇了KKBOX的日文鄧麗君除代。
的確有很多朋友讚賞我們用一台體積相對細小的Lumin class AB 160W 後級推動 801D4 普通版出良好表現。在B&W主場s222房還有一對801D4 signature。有興趣的朋友可以比較下不同環境不同價格器材配搭表現出來的效果。
今天是最後一天。
最後修改時間: 2024-08-11 09:54:50 - #1678 [DY2036], 24-08-11 02:35
我今日入過呢個攤位聽過,當時佢播緊嘅音樂有高有低推得頭頭是道(B&W 801),其實我對佢某個model U2都有啲興趣因為佢有光纖輸入同USB輸出,正好接駁我部R2R DAC。但係我極懷疑呢個是否真係播放緊網絡音樂因爲我覺得實在太好喇? 所以我詢問主持人,果真佢係播緊佢嘅server file。所以我立刻要求佢播放網絡音樂,因為呢個係佢主要嘅功能,兼且特別點名鄧麗君嘅歌。主持人將部機接咗去Tidal播咗隻鄧麗君嘅歌,講真出嚟嘅效果未如理想,不過呢個亦都唔可以證明乜嘢因為可能係個source file嘅問題。所以我覺得特別係推銷網絡播放器呢啲器材嘅主持人或者主辦單位,應該早啲做定功課或者將啲熱門嘅音樂或者歌手嘅歌喺網上搵一啲比較好嘅訊源,當做測試嘅時候就唔會畀信源品質所影響,咁樣就算對佢自己品牌推廣都有幫助。
最後修改時間: 2024-08-11 02:37:29 - #1677 [wklie], 24-08-10 23:40視聽展2024 Lumin setup:
TP Link router - Lumin L2 - (fiber) - Lumin P1 Mini - Lumin AMP (class AB 160W @ 8 ohm, stereo mode) - B&W 801D4 - #1676 [wklie], 24-08-08 22:37今年視聽展2024 Lumin 將示範最新產品 P1 Mini 及最新加入支援的串流服務。
- #1675 [wklie], 24-07-07 21:50Tidal Autoplay 是一個類似於Spotify Autoplay 和Roon Radio的功能。
Lumin 在最新的 Firmware 17.3中, 為Lumin Tidal Connect型號 (X1、T3、T2、D3、U系列、P系列) 增加了對 Tidal Autoplay 的支援, 並將逐步推出到不同的Lumin Tidal Connect型號。這是Tidal Connect相對較新的一項功能 (雖然在 Tidal app 手機播放中已經存在很長時間, 但之前無法用於Tidal Connect 串流)。
據我所知, 目前只有少數其他 streamers 支援這一功能, 所以Lumin是率先支援的製造商之一。 - 下一頁 (3 of 87)
最後修改時間: 2024-10-02 23:45:59
