- #23 [不是聰明人], 17-12-17 00:34
- #22 [不是聰明人], 17-12-17 00:27
- #21 [KK903], 17-12-16 18:47鴨記華輝$35./pc
- #20 [Cherwowo], 17-12-16 18:32
- #19 [tonywong], 17-12-16 18:30兩年前, 我問過AV contractor
佢話hdmi個頭, 無得自己夾, 要原廠線
我覺得佢點我 - #18 [Cherwowo], 17-12-16 18:29Of course use thick ducts if only for short distance.
In my case, the distance was over 5 meters. - #17 [Cherwowo], 17-12-16 18:25I did this before.
I bought bare wires and plugs from Taobao + soldered the plugs on after sifu pulled the bare wires through the walls. Doable if you have reasonable soldering skills and good eyes.
4 years now. No problem whatsoever. I also tried cat-5 cable converters before. DID NOT WORK.
最後修改時間: 2017-12-16 18:27:04 - #16 [Ming Sir], 17-12-16 18:21Hdmi 制式/頻寬 會隨時日變更,入牆做法唔長遠!
- #15 [RickMax], 17-12-16 15:48裝修電視牆藏薄身高低V線槽好平常
- #14 [Schumy], 17-12-16 15:24>行線槽
Yes this will be my last resort solution - #13 [Japhetj], 17-12-16 15:23咪用粗喉囉
- #12 [Schumy], 17-12-16 15:18>穿咗線先上牆屈喉囉
Yes it works this time but can't be replaced or upgraded in the future. - #11 [DeepSea^^], 17-12-16 15:00光纖使用最長久
- #10 [明天的明天], 17-12-16 14:52Cat5 轉 HDMI 好似好多限制
- #9 [RickMax], 17-12-16 14:39行線槽
- #8 [Japhetj], 17-12-16 14:11穿咗線先上牆屈喉囉
- #7 [singkee1], 17-12-16 13:57穿 cat5 線,兩端駁番 HDMI。
- #6 [Schumy], 17-12-16 13:52Thanks guys
自己干個頭seems very difficult, also the new type HMDI is optical, can be done this way?
I am doing this for installing the projector, lots of people must have done the same before, there must be some solution I guess. - #5 [沉默的膏蟹], 17-12-16 13:42用呢個
- #4 [dttmtong], 17-12-16 13:23光纖 hdmi 得唔得?
https://item.taobao.com/item.htm?id=562487674393&ali_refid=a3_430620_1006:1151135484:N:%E5%90%8C%E5%B1%8F%E5%99%A8:b5782bd19bd4c65df118ca8547f37af6&ali_trackid=1_b5782bd19bd4c65df118ca8547f37af6&spm=a312a.7700714.0.0
