- #38 [Japhetj], 18-02-02 11:24#37 喺亞馬遜買平好多
- #37 [Morrissey], 18-02-02 11:13有用開牙石嘅可以考慮下佢嘅AiMesh,加多一隻就等於轉咗係Mesh WiFi,不過要較高級嘅型號例如AC68U以上先得,但如果你已經有AC68U,加多九百幾蚊就可以變成Mesh WiFi,其實係平過一次過用二千蚊買Google WiFi,又唔駛浪費咗原本隻router,大家可以諗諗。
https://www.asus.com/AiMesh/ - #36 [tamtam2], 18-02-01 21:29搬屋後用轉用HKT 500m plan後一切正常未斷過
- #35 [japhetj], 18-02-01 16:2340Mbps咁慢?
- #34 [嚦嚦二世], 18-02-01 16:21Hi SB, my home is finally connected with dedicated 1000M fiber optic internet a couple of months ago. Installed 2 Google WiFi pods (1 upstairs hardwired to internet modem & the other downstairs near balcony) to upgrade wifi coverage. So far so good, usually wifi upload & download speed exceeds 40Mbps even downstairs.
- #33 [searcher], 18-02-01 15:52HI, Tamtam hing
I saw this post related to google wifi and from the thread, it seems your home wifi is provided by management company.
My home wifi is similar to yours (i.e provided by management company) and I intend to buy google wifi now
can I ask do you still have connection problem?
many thanks!! - #32 [dttmtong], 17-12-10 09:40今天收到 Netgear Orbi r50, 係非常正 bo, 無論 wifi 或 Lan 反應都好快。
以前一入主人房已經非常慢或 5g 2.4g 跳,已經係用緊 Netgear ex flagship r8000. 現在就算去到盡頭廁所位都行爆 pccw 300m - #31 [ff4300], 17-10-23 19:47用過3 100M, iCable 133M 都冇問题,兩個都唔係光纖
最後修改時間: 2017-10-23 19:49:22 - #30 [tamtam2], 17-10-21 21:52我都用緊 Google Wifi, 冇斷線問題!
師兄用緊邊間邊間網商,是否行光纖呢?
我用屋苑提供的100M和記,唔知有冇關係. - #29 [ff4300], 17-10-21 12:54我都用緊 Google Wifi, 冇斷線問題!
- #28 [明天的明天], 17-10-18 19:24又或者隻衛星接收再重新SYNC一次
- #27 [呀金], 17-10-18 19:17做白老鼠了?
- #26 [tamtam2], 17-10-18 15:16check check 上update先,個apps 好似唔覺有,斷缐後通常関電再開会正常返,可能整日都唔斷,可能一回斷幾次。
- #25 [lowyaukee], 17-10-18 15:10
又學到野喇, 謝謝指教. - #24 [明天的明天], 17-10-18 14:51有無 UPDATE FIRMWARE 後再 SETUP 過?
- #23 [tamtam2], 17-10-18 14:31冇奶油要經一經舊router,插兩個冇意義,我只想一件過。
- #22 [明天的明天], 17-10-18 13:40Netgear 果隻有VPN。
但係佢又貴過 Google 又唔可以咁樣對比 - #21 [魔鬼仔], 17-10-18 13:36如router+google就張router個wifi disable左佢
- #20 [tamtam2], 17-10-18 13:32買嘅原因係取代年事已高的舊router,唸住大廠出品必屬佳品,点知.......
- #19 [魔鬼仔], 17-10-18 13:28無話on唔on
首先你買佢原因係咩?
就係本身router wifi收得唔好先買佢
佢賣點係wifi mesh,wifi roaming,零死角,唔斷線.
反而我會router+google wifi一齊用
因router有vpn,wake on lan, 駁hdd
好多人都話買隻repeater就搞掂駛乜買佢
如用過reapter都知,速度會減半,成日斷線,唔識wifi roaming - 下一頁 (1 of 2)
