- #449 [DeepSea^^], 21-06-09 15:54不鏽鋼螺絲是屋宇處規定,上過小型工程堂就知,冷氣機掛架禁止使用拉釘、會生鏽螺絲。
- #448 [alexanderkoo], 21-06-09 15:46Having concrete opening or using overhanging frame? For both situations, must connection to adjacent building drain point to avoid ac corrosion. The AC must come with 4 in. rectangular drip pan installed at the bottom of furthest end. No extra cost. Pour water to test flow.
Even AC inclusive of installation, c Fu would still ask for extra. This is common practice, say extra drip pan, overhanging bar, blanking glass , even color of frame! to make more money. So better DIY if you know and there's existing frame.
I would test AC on ground before installation. C Fu won't. Only gets the work done and runs fast, say 1.5 HR for each AC.
最後修改時間: 2021-06-09 15:52:31 - #447 [Chia], 21-06-09 15:16千萬別叫信興裝
佢D CFu 裝工差, 仲屈你加呢加路, 如, 隔音墊, 不秀降screw. -
- #446 [G1], 21-06-09 15:10我都幫老媽訂咗三部3/4窗口,安裝時有乜嘢要留意?
- #445 [AndyTKO], 21-06-09 12:32今早,禾幫老媽訂咗的一台P記匹半淨冷窗口機到貨了,明天安裝,替換冇冷氣出嘅日立舊機。
- #444 [alexanderkoo], 21-06-03 12:46Wait for Midea U shape inverter type window unit, as found in USA. Search Youtube, many end-users raved on such. 8,000 BTU, US 350 only, yet not too deep. HK people being cheated in buying pricey and noisy appliance. (toiling in earning except investors) But local window of swing type, not of vetical sliding type, this would affect installation. Might solve the problem of corrosion for conventional window unit as well since there is special water channel for the evaporator condensate.
最後修改時間: 2021-06-03 12:48:46 - #443 [沉默的膏蟹], 21-06-03 11:38未用過。留意返匹半以下既機唔係正常呎吋,另外全線都係機身同機殼不可分離,裝果時要用特別方法,要清潔/維修亦似乎有啲麻煩。
- #442 [Reala], 21-06-03 11:11請教一下
LG 嘅窗口R32機.有冇師兄用過?效果如何?
謝謝 - #441 [phil.ng], 21-05-28 14:04兩年以上冇洗丶室內都可以好差丶豬籠也可能出吾夠風
不如上相看看 - #440 [alexanderkoo], 21-05-28 13:36Still possible but more noisy for side wall mounting. 4 holes for mounting bolts, 2 holes at further ends are split ones for sliding in the feet. Can't see any difficulty in installation.
New inverter panny 2 hp RC should be less noisy than predecessor due to dual motor design but still suffers from corrosion as other RC. Not of stainless steel chassis and accumulation of water, unless draining water at the front, a mod. but too clumsy. Old design, must store water to splash water onto condenser only for places without building drain pipe, at the sacrifice of RC life.
最後修改時間: 2021-05-28 13:37:12 - #439 [沉默的膏蟹], 21-05-28 13:16420要裝窗台,或者放上石屎躉/又或露台用吊架裝,唔可以掛外牆。
最後修改時間: 2021-05-28 13:18:34 - #438 [Ivan913], 21-05-28 10:01可以叫賣冷氣既公司搵師傅去你屋企睇地方 (要比$200, 如果買机可以扣返錢), 度過窗口位夠位至決定是否買 P記 Smaller 420. 我上個月至裝左部2匹 Smaller淨冷變頻
- #437 [G1], 21-05-28 01:01thx Koo sir for your opinion.
Smaller 系列不一定可裝窗口位 - #436 [phil.ng], 21-05-27 15:42有位裝兩匹丶為什麼不裝 small 420 呢丶又不用棚丶由現位出
靜好多呀
裝 匹半更靜丶420 室外機細丶如兩匹好食電丶因散熱不太夠
最後修改時間: 2021-05-27 15:44:00 - #435 [ABC1234], 21-05-27 13:34請問有冇師兄用過P記2匹變頻窗口機?是否會比傳統定頻2匹窗口機靜?
- #434 [Ivan913], 21-05-27 10:23#433 我而家部分體係變頻,以前部窗口係定頻
- #433 [phil.ng], 21-05-27 10:11不是看 BTU嗎?
變頻丶達標後丶只微凍
最後修改時間: 2021-05-27 10:14:02 - #432 [Ivan913], 21-05-27 10:05窗口冷氣機雖然比較嘈但依然有佢價值 (尤其是响香港): 平, 安裝簡單同費平. 另外我發覺同一樣匹數, 窗口冷氣比分體凍, 尤其是傳冷度比分體好, 例如我以前廳用2匹 窗口冷氣, 打開書房門约30-40分鐘後會感覺凍, 廚房溫度亦明顯會下降, 但而家用2匹分體冷氣就弱好多, 不過聽 Hi Fi 想靜至裝分體......
- #431 [alexanderkoo], 21-05-27 08:42As explained, it's not as cheap as room cooler, low maintainability, yet not as quiet as conventional split unit, and asking almost the same installation cost. Energy grade low,3 or 4, except General brand claiming to be 1 due to redesign of outdoor unit cooling coil. A top access panel for inverter board but still needs clear headroom.
Saw a few window split units installed as conventional ones, sitting on the floor.
最後修改時間: 2021-05-27 08:43:16 - #430 [G1], 21-05-26 19:20Why window split is freak?
- 下一頁 (4 of 26)
