- #489 [alexanderkoo], 21-06-17 15:39Because it has a circuit diagram, LOL. The compressor has sound insulation by wrapping of fibre glass material or similar.
- #488 [CS168], 21-06-17 15:36#486.
>>>頂部银色蓋説明書是建議拆掉,
但CF建議唔好拆除的部件。 - #487 [alexanderkoo], 21-06-17 15:33For inverter, high pitch only when lower than 50hz, more frequent firing on/off of transistor, hence more harmonics. Maybe it's running at 50Hz right now due to hot weather and/or better design in harmonic suppression.
- #486 [G1], 21-06-17 15:21變頻
- #485 [G1], 21-06-17 15:21定頻
- #484 [G1], 21-06-17 15:18今日安裝咗三部3/4匹,有無變頻都靜,變頻的也不覺有高頻聲,信興安裝無問題,主要係推銷水盤,老人家想安裝由佢
最後修改時間: 2021-06-17 15:19:19 - #483 [CS168], 21-06-11 23:28
小凉伴出風量及制冷未必夠樂聲制凍,
一匹半正呀!^^ - #482 [patrick88], 21-06-11 21:58水盤一樣有去水喉, 一樣有機會塞 ..........................
- #481 [AndyTKO], 21-06-11 08:33The original small drip pan is good enough. x 2
- #480 [alexanderkoo], 21-06-11 08:31#468 The original small drip pan is good enough. The larger drip pan will only be necessary after 5-6 years when the chassis is badly corroded and water leakage all over the place.
I was asked before, c-fu said it's difficult the install the larger one afterwards, blah, blah, blah. Already $350 for additional though so-called installation included.
The silicon glue is so and so. Press the tip of the gun but there might be space constraint affecting the angle of application. Need to use finger to smooth it after 20 minutes. Of course, c Fu won't wait.
Inverter type is even deeper(dual motor design), beware of rain dripping noise even there's canopy. Mom is going to install the same as yours based on price.
最後修改時間: 2021-06-11 08:44:53 - #479 [AndyTKO], 21-06-11 01:08部機完全冇花冇假係由信興派人安裝的,或且禾今次好彩遇到2位好C父都未定,今次滿意收貨開心使用中,報告完畢!
最後修改時間: 2021-06-11 01:19:53 - #478 [AndyTKO], 21-06-11 01:06臨走留低呢張紙,叫禾哋日後如果部機有乜問題可以直接打電話俾佢。
- #477 [AndyTKO], 21-06-11 01:03封邊睇落去都好順眼啩!?
最後修改時間: 2021-06-11 01:09:43 - #476 [AndyTKO], 21-06-11 01:01連啲暗位機頂封膠都冇乜偷雞,冇因禾冇俾下欄嘢佢哋做而求其做。
- #475 [AndyTKO], 21-06-11 00:59所以四邊都拍下來分享一下。
- #474 [AndyTKO], 21-06-11 00:58禾覺得都算幾好。
- #473 [AndyTKO], 21-06-11 00:57其實呢2位C父手工如何就睇法見人見智,不過見佢哋啲封玻璃膠手工還可以接受啩?
- #472 [AndyTKO], 21-06-11 00:53新機係好靚仔,但舊咗乜機都會變醜樣。
- #471 [AndyTKO], 21-06-11 00:51開機大約10分鐘左右冷coil的銅喉已經凍冰冰起水。
- #470 [AndyTKO], 21-06-11 00:49冚返個半透明膠蓋睇落去仲靚仔!
- 下一頁 (2 of 26)
