- #25749 [0925], 24-04-25 08:29
- #25748 [0925], 24-04-25 08:27
- #25747 [0925], 24-04-22 09:24https://forums.timezone.com/index.php?t=tree&goto=7769723&rid=0#msg_7769723
最後修改時間: 2024-04-22 09:25:47 -
- #25746 [0925], 24-04-21 20:24https://forums.timezone.com/index.php?t=tree&goto=7769685&rid=0#msg_7769685
Technical Specifications:
The case, in stainless steel with aged bronze PVD treatment, measures 44.8mm. It is completely filled with a special oil that enhances the dial, creating the illusion of absence of glass, with a more intense color effect and greater readability. It has a curved AR-coated sapphire crystal. Distinctive crown protector on the left. The caseback features an innovative locking system (Locking Ring System) with quick battery replacement. It is water resistant to 50 meters.
Movement is the Swiss precision quartz Ronda caliber 712.3 which is lubricated in an oil bath. Functions are: hours and minutes.
最後修改時間: 2024-04-21 20:24:51 - #25745 [0925], 24-04-20 21:08https://www.thetimebum.com/2024/04/hemel-gallant-usaf-edition-and-eylandt-resolute.html
最後修改時間: 2024-04-20 21:09:11 - #25744 [0925], 24-04-20 13:33https://forums.timezone.com/index.php?t=tree&goto=7769630&rid=0#msg_7769630
最後修改時間: 2024-04-20 13:33:53 - #25743 [0925], 24-04-20 13:32https://forums.timezone.com/index.php?t=tree&goto=7769487&rid=0#msg_7769487
最後修改時間: 2024-04-20 13:32:10 - #25742 [0925], 24-04-20 13:30https://forums.timezone.com/index.php?t=tree&goto=7769485&rid=0#msg_7769485
最後修改時間: 2024-04-20 13:30:33 - #25741 [0925], 24-04-20 13:26https://forums.timezone.com/index.php?t=tree&goto=7769483&rid=0#msg_7769483
最後修改時間: 2024-04-20 13:26:31 - #25740 [0925], 24-04-20 13:24https://www.ablogtowatch.com/watch-review-archimede-outdoor-protect-39-black-forest/
最後修改時間: 2024-04-20 13:24:24 - #25739 [0925], 24-04-17 19:46https://wristreview.com/introducing-the-chanel-j12-automaton-caliber-6-watch/
最後修改時間: 2024-04-17 19:46:49 - #25738 [0925], 24-04-17 19:42https://www.ablogtowatch.com/watch-review-gorilla-fastback-touring-aurelia-39mm/
最後修改時間: 2024-04-17 19:43:06 - #25737 [0925], 24-04-17 12:39
- #25736 [0925], 24-04-17 12:33
- #25735 [0925], 24-04-17 12:30https://forums.timezone.com/index.php?t=tree&goto=7769431&rid=0#msg_7769431
最後修改時間: 2024-04-17 12:31:16 - #25734 [0925], 24-04-17 12:27https://forums.timezone.com/index.php?t=tree&goto=7769430&rid=0#msg_7769430
最後修改時間: 2024-04-17 12:28:25 - #25733 [0925], 24-04-17 12:24https://forums.timezone.com/index.php?t=tree&goto=7769428&rid=0#msg_7769428
最後修改時間: 2024-04-17 12:24:59 - #25732 [0925], 24-04-15 22:59
- #25731 [0925], 24-04-15 22:44https://forums.timezone.com/index.php?t=tree&goto=7769368&rid=0#msg_7769368
最後修改時間: 2024-04-15 22:44:17 - #25730 [0925], 24-04-15 22:41https://forums.timezone.com/index.php?t=tree&goto=7769365&rid=0#msg_7769365
最後修改時間: 2024-04-15 22:42:11 - 下一頁 (3 of 1290)
最後修改時間: 2024-04-25 08:30:01
